Black Algae and dying pump
Apr 19, 2011
5
Howdy! I've been lurking off and on for a while, and up till now I've always found the answers I was looking for without needing to post. No such luck with this one, though, so here goes:
About four or five days ago, I started noticing what has to be black algae on the wall of my in ground pool around the light fixture. I have a basic idea of what to do about it, but unfortunately, I'm pretty sure my pool pump is about to die. The noise level has been increasing for a few weeks, and it's just about intolerable now, and I've just flipped it off (taking the SWG with it, of course). I'm likely going to have to replace it, but that will take a few days, at a minimum, and I'm not sure what to do about the algae in the interim. (It's fairly small right now, maybe 3 inches by 8 inches or so).
I have a Blue Diamond pool robot that I was going to use to filter the water until the pump is operational. Can I try tackling the algae problem while that is my main water filtration system? I don't want to damage it with higher chlorine levels or something like that, or waste my time if it's not up to the task.
Thanks for any advice!
Sometimes they start to make noise if theres a clog, acrorn bits etc.
Is there alot of air in pump basket?
Try opening pump and use a copper ground wire to get crud out.
Is robot suction or return?
I know algeacide is not liked here but would this be an exception? guys?
ps is filter size in your sig correct?
Whoops, off by a factor of 12 there on the pool filter. Thanks for the catch!
There's not a lot of air in the basket now, but I had a leak (fixed a few weeks back) and for a while I was running a lot of air through there when the water level got too low. I suspect that is what caused my pump to become so noisy now. Still, it's worth checking for crud, so I will. Thanks.
As for the robot, it's self contained -- no hoses running to it from either the skimmer or the return.
If the black is only around the light fixture, then I would suspect that it might be related to the light. Perhaps corrosion of metal, or something in the niche. Has your chlorine been low enough for algae to form? (Less than 7.5 % of the CYA?).
If it is algae, you can go to shock level using liquid chlorine and mix it in by thoroughly brushing the entire pool.
A picture would help if you could post one.
Agree with above - bleach to shock level, pull light, scrub behind it, brush pool, put light back (if it will entangle robot), run robot, repeat.
Can't get a pic quite yet, but I just ran the numbers:
FC 6.0
CC 0.0
TC 6.0
pH 7.6
T/A 45
CH 300
CYA 50
That's this morning, with the pump and SWG only running for a short period -- an hour maybe -- yesterday. Alkalinity has never been that low before, for whatever that's worth.
Will try to post a picture after church. And thanks again for the help!
The current FC is sufficient. However, if the FC was previously too low, then it might be algae. If the FC has not been less than 7.5 % of the CYA, then that would make algae less likely.
Your overall numbers are too low for a plaster pool. I would raise the TA up to about 60 or 70 ppm, allow the pH to go up to about 7.7 or 7.8, and raise the Calcium to about 350.
What is the water temperature?
How old is the plaster and what is the general condition of the plaster?
Is the black mainly around the light screw?
Hogtown:
Agree with what many others have said about going through the shock process and cleaning behind the light fixtures and any other nooks/crannies where algae can gain a foothold due to reduced circulation in those areas. Also would brush the pool since your pump's operation appears to be impaired. Algaecide is of little to no value on an existing algae bloom, so I wouldn't bother using that.
As for the circulation, the best remedy is to repair or replace the pump ASAP. Until that happens, here are a couple of options that can be used on a temporary basis:
  • • If you have another portable pump of some sort, you can try using that to recirculate the water. True, it will not be filtered but it will provide some water movement which is better than nothing.
