Thread: cal to high
    SOUTHREN VIRGINIA
    31
    cal to high
    i am making my second post as the first one i didnt do it correctly --my question is that my calcium nunbers are to high ,i have a 13,500 gal aboveground and would like to know what the dangers are from numbers being to high -all other numbers are good except my t/a was also to high so i added 9 lbs of bakingsoda and its okay now,just switched over from bacucil this year .........to chol..what a difference
    a/g 24'round 4' app 13500 gal sand filter 16''hayward (100lbs sand)1hp single speed pump on timer 12 on 12 off day &night and i use the bbb maintaince
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: cal to high
    Quote Originally Posted by oran
    Welcome to the forums!
    9lbs of baking soda should have RAISED your TA by about 48ppm, not lowered it. High calcium and TA can cause cloudiness in the water. I'd recommend you post your actual numbers. The "conventional wisdom" numbers you see most places are wrong, and many of the numbers interact. Post your pH, TA, and CH at least.
    I deleted your first post since you reposted with info.
    SOUTHREN VIRGINIA
    31
    thank you for the quick response,iam away from my pool now but will post numbers soon thank you again,this is soooo much easier than the other pool program ive been trying to get a password from seems forever --sent cash but no action...this is GREAT TO ME
