Results 1 to 15 of 15
Thread: Calcium is way high please help
    Dallas
    51
    My pool just got done and my tap water levels were:
    FC = 1
    CC = 2
    PH = OVER 8.2
    TA = 80
    CH = 150
    CYA = 0
    They started my pool and my calcium jumped to 370.
    They stabilized my pool two days ago and my calcium was 450
    NOW, These are my levels today and my calcium has steadily gone up.
    FC = 10
    CC = 0
    PH = 7.5
    TA = 80
    CH = 550 (DID TEST TWICE TO BE SURE)
    CYA = 40
    The only thing being used right now are trichlor pucks while I go through the breaKing in period on my plaster. Do they have calcium in them? I am really getting worried about how high the levels have raised in a week.
    Greg
    Greg Watson
    15,500 Gallon Freeform IG Martinique Luna Quarts Pool, Jandy CL580 Cartridge Filter, Jandy Stealth Pump, Rainbow 320 Inline Chlorinator and Polaris 280 Pool Cleaner
    Oct 2012
    209
    Re: Calcium is way high please help
    Your calcium levels have went up from the new plaster. I would reccomend vaccuming to waste as you need to clean and refilling. Your calcium levels aren't ridiculous, but keep you PH in balance or you will have issues.
    24' round above ground, 13500 gallons, vinyl liner, 18" Sand Filter
    Oct 2012
    209
    And no trichlor don't contain calcium.
    I don't think that new plaster could cause the calcium levels to go up that much. I would ask the service people if they have added calcium.
    Support the site
    Hi neighbor! These folks here will get you fixed up!
    Helen
    Dallas Area, 16,000 gal IG, Easytouch 8 computer, Intelliflo 3HP Variable Speed pool pump, Pentair Smart Pump 4x160, Pentair 3/4 HP Booster Pump, FNS 60 DE 60, Mastertemp 400, Rainbow 320, Dual Timer w/ freeze protection, Intellichor SWG, TF100 Test Kit, POOL FILLED AUG 3, 2012, ORDER YOUR TF100 KIT FROM http://tftestkits.net
    http://www.troublefreepool.com/under...ie-t49936.html
    Dallas
    51
    Quote Originally Posted by JamesW
    I took a sample to Leslie's near me and they confirmed the calcium numbers. They recommended Caltreat but I have seen mixed reviews on it.
    Greg
    Greg Watson
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Keep an very close eye on PH and do not let it go above 7.8 or you risk calcium scaling. 550 CH can still be managed but not if you can not check PH daily. Otherwise I would suggest a partial drain and fill to lower your CH level.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Even if Leslie's confirmed it, I'd question that reading unless it was done with a speedstir.
    My CH level dropped several hundred points when switching from hand swirling to speedstir. Nothing else changed. Keep the pH in the lower reaches of the comfort zone and you'll be all right. My CSI is still negative despite CH levels over 800. Play with the pool calculator and see what lowering pH and TA will do.
    You can also pump out a few inches at a time to water the lawn, as I do. It might only be a 5% reduction each time, but it helps, and none of the water is wasted.
    I think that it's important to find out why the calcium is so high. For the plaster to contribute that much calcium, I think that it would have to be defective. If the calcium came from someone adding it, then they should be responsible for either explaining why they added so much, or lowering it.
    Also, if you have copper in the water, then the test might be inaccurate. Try adding 5 drops of R-0012 first and using a speedstir.
    Support the site
    Quote Originally Posted by Watson
    FC = 1
    CC = 2
    PH = OVER 8.2
    TA = 80
    CH = 150
    CYA = 0
    FC = 10
    CC = 0
    PH = 7.5
    TA = 80
    CYA = 40
    Greg
    What happens to a pool when the calcium levels are too high?
    Richard320's Avatar
    Jan 2010
    19,051
    Quote Originally Posted by Emilio.Largo
    You get scaling. It can look like your pool has a skin disease, and it can get very coarse, like sandpaper.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Even with high calcium levels you can prevent scaling by keeping a careful balance of pH and TA to produce a CSI at zero of very slightly negative. I have been able to prevent scaling with CH levels as high as 1000.
    chiefwej
    Dallas
    51
    Quote Originally Posted by Richard320
    I ordered and received the speed stir and you were right. My 550 CH dropped to 490 with the speed stir. This little device is awesome and makes testing so much easier.
    Thanks for the tip.
    So right now I am sitting at
    FC - 5
    CC - 0
    PH - 7.5
    TA - 80
    CH - 490
    CYA - 40
    Pool is crystal clear and is looking great. If only summer had held out a little longer here in Dallas
    PS turned off the Rainbow and switched to bleach yesterday. I am hoping to be able to alternate all winter to keep my CYA right around 40 and keep my FC at a consistant 5
    Greg Watson
    Richard320's Avatar
    Jan 2010
    19,051
    You will likely find that as the water temperature drops, your chlorine consumption will go way down. And if the CYA is 40 now, and you don't have it overflow with rain, it will probably be close to 40 when it starts warming up again.
    Dallas
    51
    We do have a rain overflow and I figure between evaporation, as well as, overflow, my CYA and CH will drop as the winter goes on. My wife is not into all this pool stuff, she just wans to swim , and I travel quite alot.
    I figure I will turn the rainbow on for the days that I am away from home usually 3 days a week, and turn it off and use bleach when I am home. This should keep my CYA consistant over the winter, or at least that is my hope.
    By start of summer I should have my parastalic pump set up in place.
    Greg Watson
