Thread: pool cleaning devices
    Houston, TX
    1,094
    Hello to all,
    I have taken the advice of Mark to not go with the in-floor cleaning systems and wanted to get some opinions on other cleaning devices? Below are the spec's, but wanted to note we are located in SE Texas, no leaves from trees [palm trees only], pool depth is 3.5" 5" 4.5". Pool equipment will be located very close to pool. If there is anything else you need to know, pls let me know?
    Thank you very much,
    tstex
    Gallons: Pool 13,500, Spa 700
    Pumps: Pool, 3/4hp Jandy Stealth, full rated, spa & pool cleaners, 1.5hp Jandy Steath, full rated, scuppers, 1hp Jandy Stealth, full rated
    Equip: filter Jandy CL/340m 340sqft, heater jandy LXI250 250KBTU, pool cleaner Paramount in-floor CyClean, Chlorinator Fusion Nature 2, airblower Polaris QT 1.5HP/120 V
    Controller Zodiac / Aqualink RS/ PDA /Smt Ph App
    Power Center: Zodiac /Aqualink RS Power Center
    InGround 15K gal, 18'x30' 3.5' to 5.5' depth w/ 9'x9' spillover Spa, Pebblesheen w/ Travertine, Hayward 3 HP VSP, Hayward C4030 Cartridge, Hayward 1.5 HP for 2 Scupper columns, ProLogic, PL-PS-8 Panel, Hayward H400FD 400K BTU Heater, 3 ColorLogic LED, Spa Blower, TF-100 w S-Stick, QC Tiger Shark, Autofill If you enjoyed your TFP experience, please consider donating to Support TFP!
    happyheathen's Avatar
    Sacramento CA
    225
    Re: pool cleaning devices
    Ummm...
    Nobody can tell you which device will be best for you.
    There is a section in Pool School on cleaners, there are threads here discussing various cleaners.
    Google will bring up 1000's of discussions of anything you name.
    This is your decision to make.
    Dave
    Sacramento
    1980's 15,000 Gal IG Plaster; 1 1/2 hp Hayward Northstar; Hayward Swimclear C3025 Cartridge Filter (325 sq ft, nom.); Pentair Legend; Polaris PB4-60; Equipment 40' from pool. p.s.: it's an aye-aye.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Budget, level of frustration if it breaks, ability to handle heavy object in/out of water - all play a role.
    As advised take a look and come back after reading with questions. I'm sure it will start to make sense.
    - Sent using Tapatalk
