Thread: Installing a pool railing stair handle $425
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Hello All,
    I'm getting ready to have a pool railing installed received a quote of $425. Does this sound reasonable?
    It's a basic Stainless Steel handle. Will not be mounted in the water, but in the deck. The concrete deck will need 2 holes drilled, the mounts installed, hydraulic cemented in, 24 hours later they mount the handle.
    Qwaxalot's Avatar
    Jun 2012
    439
    Re: Installing a pool railing stair handle $425
    Quote Originally Posted by bobodaclown
    Hello All,
    That rail should be electrically bonded. $425.00 sounds cheap.
    I would not trust a railing held in place with hydraulic cement (too much torque when using the rail).
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    Jul 2012
    CA
    240
    Quote Originally Posted by Qwaxalot
    Hello All,
    That must be one big a$# drill bit.
    When it comes to a regular porch step handrail, i thought being cemented in was better then having a 4 bolt base? because of kids loosening nuts from playing around.
    How do you get it bonded?
    hey thanks
    25k I/G ecostar ccplus Polaris plaster
