Thread: strange question
    strange question
    I have a customer that has an old DE filter. They want to replace and dont have any preference of which filter. I have a sta rite cartridge filter in stock that they want me to put in because ill give it to them cheaper. Anyway The old filter had a brass push pull backwash valve and copper piping going in to the heater. Can i just slide the new filter into the backwash valve and just not use it? or will this cause a problem?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Re: strange question
    Quote Originally Posted by keene3b07
    I suppose there would be a slight loss of head making the extra bends inside the valve. But really, the odds of the plumbing lining up is pretty slim. If uou have to cut pipes, may as well do them all.
    22,549
    As Richard said, there's a slim to none chance that it'll line up or that the ports are the correct orientation if they do. I'd cut it out and replumb to the new filter with PVC.
