Thread: Air Pillow deflated
    Air Pillow deflated
    HI all,
    I closed my pool about a month ago, and the brand new 4x15 air pillow is deflated already!
    Should I remove teh cover - reinflate and try again? or isn't it a big deal not to have the air pillow? I live in Norther NJ so considerable snow and rain build up is very possible between now and opening time.
    Thanks
    Dave
    DP
    26x15x52 AG
    Hayward DE Filter
    May 2012
    Montville NJ
    545
    Re: Air Pillow deflated
    Quote Originally Posted by NJPoolNewbie
    HI all,
    Thanks
    Dave
    My understanding is that the air pillow is used to provide a cushion for ice expansion (as opposed to it blowing out the sides of your pool). It is not there to make snow and rain run off.
    The previous owners of my pool did not use one last year
    I used one this year when I closed.
    My neighbors did not use one last year or this year
    We are all Northern NJ as well.
    If you tied your in the middle, you could untie one string, tie a longer string on that end, then pull it to the other side with the other sting, reinflate it, and then pull it back to center. All without having to remove the cover (just loosen the wire hold down).
    I will say, that with the pillow in there, it makes siphoning water off of the cover a lot easier.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    Jun 2011
    Northern Maryland (near Delaware)
    170
    I use 2 4x8's last year ice broke one. I was talked out of 4x15 by pool store just in case one broke. If it was me I would pull it out, put duct tape over the valve to give a little extra support from the weight of ice and snow pushing it open. The only down side is they usually move to one side I have them tied across the pool on separate lines.
    15'X30'X52" AGP AquaSports Grande Buttress Free (10,620 Gallons), Hayward Dreamline S190 W Zeobrite, 1.5 HP Hayward PowerFlo LX, AquaLuminator Light+ fountain attachment, Pool Rover, Tf-100 test kit, Speed Stir.
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Sounds like your pillow either has a hole or the cap wasn't pushed in all the way. I also ended up with a deflated pillow, I tried to get another year out of my old one....not so much. I just installed my new 4x15 pillow today. I tied up one end of the cover so it wouldn't slide off and folded the cover back from the opposite end a bit more than halfway. I pulled the old pillow out, moved my anchor ropes to the new one and dragged it back in. Then rolled the cover back over the new pillow. This after some choice words. Never fun on a big pool and having water on the cover.
    As for leaving it out, your call. There are differences in opinion as to if it helps with ice. I would like to think so. It definitely makes the water easier to drain off.
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
