Results 1 to 9 of 9
Thread: empty swimmingpool question
    Mar 2012
    spain
    48
    hi
    this is my swimmingpool in spain
    i gues this is called an above swimmingpool?
    so for the last 15 years its been full all winter
    now are we thinking of empty him this winter for 4-5-6 months
    any bad things can happen when he empty?
    or things i sure need to do when leave him empty?
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: empty swimmingpool question
    They'll need more information, most likely. Things like what your winter is like, the water table level, etc.
    Mar 2012
    spain
    48
    average weather
    http://www.holiday-weather.com/benidorm/averages/
    water table level?
    is this water level in ground itself?
    if this is water table level? all ground here is rock
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    The real question is "Why do you want to empty it?". Your climate looks like it could freeze occasionally, which means you would have to empty all of your plumbing and the filter and pump and seal all the lines. I can't think of any benefit from not leaving the water in the pool.
    Mar 2012
    spain
    48
    hi
    i want to empty it because its verry dirty
    and if i take in account all the water i need to refill, all cleaning i need to do, and all electricity etc i would spend this winter
    i come out more cheap empty him, and refill him later
    there is no freezing here
    the lowest is about 4-5 degrees celsius it gets
    SW Indiana
    9,199
    Unless you can cover it, it will accumulate rain water over the winter and probably be fairly dirty in the spring.
    Is the pool surface plaster, tile or is it a liner?
    Mike_W's Avatar
    Aug 2011
    Orange County, California
    142
    More questions along those lines - What is it made of? Is it partially buried in the ground or does it rest on a foundation?
    Mike
    ~17' x 34' IG pool with attached spa - 20500 gallons - Gunite with a "pebblesheen"-ish finish
    Jandy iAqualink with iPad and Jandy PDA remote - Pentair IntelliFlo VS 11018 Pump
    AquaRite SWCG - Pentair SMBW 4060 DE Filter - Really Old Raypak heater
    "Wall-E" an Arneson-Hayward Navigator - A couple of Jandy/Zodiac WaterColors LED Lights - Blue-White F-1000 Flow meter
    Mar 2012
    spain
    48
    its concrete with tiles
    everything here is rock, with a thin layer of dirt/sand
    so basicly its build on rock
    here some fotos to make it more clear
    SW Indiana
    9,199
    Very interesting construction. You may wish to contact a builder to ask about the effects of air exposure and drying on the grout.
