Results 1 to 7 of 7
Thread: Skimmer Closing
    Jun 2011
    Michigan
    41
    Skimmer Closing
    My skimmer has two holes in the bottom. One that has the plumbing hooked up that goes to the pump. In that one I put a gizmo in it for the winter. The second hole is not used. For this hole, should I leave it unplugged to allow the water to drain out of it over the winter, or should I keep it plugged and put some anti-freeze in it. I have dropped the water level about 3 inches below the skimmer.
    24' x 52" round Radiant Metric GT, Fully Buried.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Skimmer Closing
    Maybe take a picture. If this was an inground pool the second hole is usually not hooked to anything but I wouldn't leave it open as no to wash away any backfill. I don't see to many AG skimmers with a second hole. If the skimmer is buried I wouldn't let water drain through the skimmer.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    22,544
    Re: Skimmer Closing
    That second hole is most likely capped under the bottom if you don't have a main drain. It's a common practice to cap it under the bottom rather than plug it. I highly doubt that any water is going to drain out of it.
    If you don't have a MD, just pour a little antifreeze in it to displace the water and you'll be good to go.
    Jun 2011
    Michigan
    41
    Re: Skimmer Closing
    thanks, I'll keep it plugged. the only reason I asked was because I was watching a youtube video of a pool company closing an inground vinyl pool, and they recommended keeping it open for the winter to allow water to drain out of the skimmer. I did not do that last year and did not have any problems, although it was a mild winter. Mine was capped underneath, I installed the plumbing myself and yes it does not connect to anything. I am in the process of adding some extra support for the skimmer so it would be easy to uncap it from underneath and leave it open.
    Jul 2012
    Way north of Chicago
    40
    Re: Skimmer Closing
    Just out of curiosity, what is the second hole for? Our IG has these too, and they are plugged with screwins, but we do have a main drain.
    25000 gal inground curved L shape - concrete, fiberglass walls - with Jacuzzi Sherlock 160 cartridge filter, Laars Lite LLG gas heater & Klean-a-tron robot
    near the pool: Cookshack Smokette, Akorn Kamado grill, putting green
    in the shed: Deere greens mower, Simplicity FC-16 front cut mower
    22,544
    Re: Skimmer Closing
    It's used for either an equalizer line or to connect the MD to the bottom of the skimmer. In a lot of cases it's not used at all. In your case, I suspect the MD line is ran all the way back to the pad.
    Jul 2012
    40
    Re: Skimmer Closing
    Dave - You guessed it. Thanx for the info.
