Thread: anyone use there cyclone or might vac to blow out sprinkers?
    Oct 2010
    michigan
    284
    anyone use there cyclone or might vac to blow out sprinkers? is it possible? as the sprinkler hook up line is small like air compressor line.
    would it have enough pressure to blow em out?
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    22,551
    Re: anyone use there cyclone or might vac to blow out sprink
    It would most likely be fine for blowing them out. It doesn't take a lot of pressure to blow the water out of them. Make sure oyu blow it plenty long enough to get all the water out.
