Thread: Can I close the pool but keep open the attached spa?
    I have an Anthony pool, circa 1985, with the "caretaker" system. It has an attached spa. My wife would like to close the pool, but keep using the spa. Is this possible to do?
    21'x52" Asahi Fijian AGP 11,000 gallons, sta rite 1 1/2hp pentair pump, 60 gpm, 250# cristal flo 2 sand filter with zeolite media, foam cove, DIY finished in 7/12
    38,428
    Re: Can I close the pool but keep open the attached spa?
    Is the caretaker in the spa as well? Do you have returns into the spa that are not the floor system? To maintain circulation you need to be able to have suction and return to the spa only and then maintain the chemical levels. If the only return is the jets, I am thinking the constant aeration would drive the pH up.
    Where are you located? What weather are you expecting? Add your pool and equipment info to your signature.
    Qwaxalot's Avatar
    Jun 2012
    439
    Quote Originally Posted by esajl
    This is only possible if the pool and spa can be totally isolated from each other. Often problematical.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    The spa has two drains, and one caretaker valve in the floor to circulate chlorinated water to the spa when the pool is the primary use. It has four jets that are specific to the spa when that is the primary use. The valves for the system can be turned so that the sole (I think) intake and return are for the spa, the pool, or both. Whether turning the valves so that the sole drain and return is through the spa jets constitutes a "total isolation," I don't know.
    I'm in NY and obviously the swimming season is over.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    I always wonder about the pool/spa combo here in the north, for this reason. Can you contact the original builder and find out what his thoughts re winter were on construction? Perhaps that was accommodated in the design. You'd need a winter cover for the spa part the could handle the snow load -- is it a shape that can be covered?
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
