Thread: Pentair Superflo - 1.5HP - Stopped Working
    Yesterday I noticed my Pentair Superflo 1.5HP (dual speed) had stopped. It had tripped the cirtcuit breaker, which I reset, but it still wouldn't work. I checked for supply voltage to the pump (220v) - it is getting the supply. I replaced the capacitor. That also didn't fix the problem. Is there anything else, like a thermal trip or fuse? Any suggestions would be appreciated.
    Sam
    Feb 2008
    Denton, TX
    5,061
    Re: Pentair Superflo - 1.5HP - Stopped Working
    Welcome to TFP!
    How old is this motor? If it isn't the capacitor, it may be time for a new one.
    Thanks for the quick reply. The motor's only 20 months old. I replaced a single speed pump that had worked flawlessly for 20 years with the 2 speed Pentair in February 2011. I figure it shouldn't be worn out by now and it's probably something else.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Does the shaft turn smoothly? Is the impeller jammed? Hi/Lo switch inop?
    Shaft turns smoothly. Impeller turns. Hi/Lo switch resistance in on-state (not powered up) 3 ohms (either direction). Everything looks normal.
