Thread: Spa size (Is it possible to make the spa too big?)
    mnittler's Avatar
    Sep 2012
    South Texas
    58
    What would the ideal size round spa be? If you had to do it again what size spa would you install? We currently have an 8' round spa in our new construction pool contract but it can be changed if required at this time. Seniors with kids and grand children.
    21,500 gal sport pool, 8' spa, beach, 400k btu LP heater, Pentair IC60 SWG & #300 Tablet Feeder, 60 sqft DE filter, Paramount in-floor PoolValet 3 cleaners, Debris Canister, Polaris 360, Pentair VFD 3hp pump, IntelliPh, Geysers & Turbo Twister Slide w/1 hp pump, Color LED Pool & Spa lights, E-Z Touch8 control system, Wireless controller. Test Kits:TF-100, Taylor K-1004, CYA K-1720, Phosphate K-1106, Salt Water K-1766, Hach CN-39WR.
    bigfunky's Avatar
    Jun 2012
    Wayne, PA
    137
    Re: Spa size (Is it possible to make the spa too big?)
    A 8ft spa will hold 8-10 people and 7 ft spa will hold 6-8 people, I'd stay with the 8ft spa
    26,000 gallon gunite IGP with 50 sq ft Spa, Jandy VS FloPro 2hp Pump, Jandy DEV48 Filter, Jandy AquaPure SWG, Jandy AquaLink PDA-PS6 Controller, RayPak R406A Heater, Polaris 380 Cleaner, completed April 2013
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Quote Originally Posted by bigfunky
    Is this anything like a pizza, where they say it serves 10 for a giant, but it really only serves 4? :P
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    Jun 2011
    Long Beach, CA
    2,790
    An 8 foot spa should be good and would be my choice if I had the room for it. Do remember that the larger the spa means more time that you will need to heat the water. We use our 7' spa all year long and are usually in it 3-4 times a week during the winter and need to raise the temp from around 60 degrees.
    mnittler's Avatar
    Sep 2012
    South Texas
    58
    They have quoted a 333k btu propane heater. Do you think this is big enough for an 8' spa?
    mas985's Avatar
    Pleasanton, CA
    11,741
    When it comes to heaters, the bigger the faster they will heat the water so I would go with a 400k heater. I have that on a 7' spa and when it is really cold out, it can take over an hour to heat the water from 45 up to 102. It will take a 8' spa 30% longer to heat up.
    Mark
