Results 1 to 7 of 7
Thread: Pool Closing Chlorine Level?
    Jul 2009
    Long Island, NY
    267
    Okay, I've read the Closing an Inground Pool thread several times and don't understand something. I plan on raising the FC to shock level about 1 week prior to closing and keeping it there for 3 days. After that, I will let it drift back down. The day before closing, I will add polyquat 60 and let circulate for 24 hours. My question is on the day of closing should I test the FC level and bring it back up to shock or somewhere in the middle? I have read that the Polyquat 60 uses up a good deal of the FC and am wondering what my actual FC level should be when closing.
    Free-form concrete walls with vinyl liner, 18,000 gallon capacity, Jandy 1.5HP e-Pump, Jandy DEV48 DE filter (using cellulose media), Jandy AE2500 heat pump, Jandy Aqualink Power Center with 14-blade cell kit and Jandy PDA-P8 wireless control system.
    30,408
    Re: Pool Closing Chlorine Level?
    Close at shock level.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by poolneophyte
    My understanding is that FC eats polyquat which implies that adding FC after the polyquat would make the polyquat vanish more quickly. I don't think you are expected to raise FC to shock after adding the polyquat.
    Jul 2009
    Long Island, NY
    267
    Quote Originally Posted by UnderWaterVanya
    Therein lies my confusion! I'm not sure what to do. I don't want to waste the Polyquat 60 that I just added the day before.
    Jun 2012
    Mint Hill, NC
    2,589
    I think it's pretty clear that Buckman Labs thinks you should not raise the FC back up:
    i-am-a-stranger-at-the-pool-store-t8609.html#p71181
    It's also pretty clear that Polyquat may not make it the entire winter:
    post76410.html
    I'm not really all that clear why we want to use it - I'm also considering it - but now I'm questioning myself.
    I raise to shock level (slightly above) and let it circulate for about 12-18hrs then close it. No algaecide.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Jul 2009
    Long Island, NY
    267
    The only reason that I am using the Polyquat 60 is that I have half a quart left over from last year. After its used up, I doubt that I will buy any more. Thanks to all for your input.
