Thread: aqua rite electronic chlorine generator no led or lights
    I replaced the thermistor on the pcb because I had a no power light issue. It worked and all was working after I soldered it in yesterday, but today when the system turned on there are now no lights lit up, and the led won't light up either. Pump turns on, but seems like the board is completely dead now, and the fuse that comes out of the bottom still looks fine. Any ideas, or am I unfortunately looking at a new/used board? I do have a see through turbo cell so I can see if it's generating or not. Definitely not...
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Re: aqua rite electronic chlorine generator no led or lights
    See if you cooked your new replacement part on the board.
    Factory Warranty Station for:
    Qwaxalot's Avatar
    Jun 2012
    439
    Quote Originally Posted by phoqus
    By all means reexamine the replaced current limiter.
    But, don't trust a visual inspection of the glass fuze; either test it with a VOM or replace it, then you'll know.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    I experienced a similar problem, after testing the current limiter and finding it functioning, I removed the board and inspected the reverse side. I discovered a slight brownish tinge behind the top of two relays on the board. Ordered replacements which also were relatively cheap. It was a little more work to replace because there were more points of contact with the board. After replacing I fired it up and all is well. I had to repeat this process with the same relay about 18 mos. later. Omron GBP-1C4P 24V relays.
