Results 1 to 9 of 9
Thread: My Pool Chemistry - New Pool
    SWG, new plaster pool. First pool measurements, aren't good:
    FC - 0
    CC - 0
    PH - 7.8 ish, maybe a little higher
    TA - 60
    CH - 3300
    CYA - 0
    Salt - 1560
    Pool Vol - calculated @ 44883
    CH is way out of whack. I know the forum recommends emptying the pool, but seriously? Opening the pool they did the chemical bath where the ph was way lower to dissolve the plaster dust. They told me the plaster was going to continue to cure up through the first year. Soooo, drain the pool or get the other numbers in order?
    28,500K, 520sqft cartridge filter, prism quartz pebble antigua, Pentair Intelliflo SWG, Pentair Legend Platinum robot, date TBD
    Jul 2012
    Dumfries & Galloway, Scotland
    296
    Re: My Pool Chemistry - New Pool
    Hi, how are you reaching your test results? Are you sure your CH is 3,300? How did you arrive at this value?
    Regards
    Stuart
    Stuart Murray
    Scotland UK
    UK NPPOC
    I did the tf100 drop test. A little background..I just opened my pool. PB did the acid wash to cure the plaster. Today I cleaned the filter (yuk!) for the first time. I still have a lot of dust when I sweep, so I am gonna just be patient with those numbers. I think I need to filter everything out before it will do any good to empty the pool.
    Now for the rest of the numbers..I am adding muriatic acid, stabilizer and salt. I know I need to add bleach, the search for salt distracted me from that. Everyone in town except Leslies is running out, setting up for Christmas..lol I will add those and see where the numbers go.. more tomorrow. Thanks very much for the response Staumurr!!
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by arvven
    FC - 0
    CC - 0
    TA - 60
    CH - 3300
    CYA - 0
    Salt - 1560
    3300??? That means it took 330 drops to change color. Ouch... I'm getting cramps just thinking about all those drops and all the swirling!
    -sent with Tapatalk 2
    OMG..ur right. It should be 33x10...330. Whew. I was freaking out. Thanks for the check! I will adjust tomorrow!
    Jun 2012
    Mint Hill, NC
    2,589
    Whew... that makes more sense! 330 is no biggie - just calculate your csi and determine what you need to adjust.
    38,295
    Generally it is advised to not any salt for 30 days after a pool is plastered. Did the builder say it was fine to add before then? Given the experiments done and described in other threads, I would advise against adding any salt for at least a month since the plaster will cure better without it.
    Ooh and you do not need pool salt ... solar salt for water softener is cheaper and the same thing ... as long as you avoid any with additives.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    I thought the something! Actually, read it on the site..lol. The builder added the salt. Maybe I should just let it stay low and treat with bleach?
    How are your numbers looking now?
    Helen
    Dallas Area, 16,000 gal IG, Easytouch 8 computer, Intelliflo 3HP Variable Speed pool pump, Pentair Smart Pump 4x160, Pentair 3/4 HP Booster Pump, FNS 60 DE 60, Mastertemp 400, Rainbow 320, Dual Timer w/ freeze protection, Intellichor SWG, TF100 Test Kit, POOL FILLED AUG 3, 2012, ORDER YOUR TF100 KIT FROM http://tftestkits.net
    http://www.troublefreepool.com/under...ie-t49936.html
