Thread: when closing pool, chlorine level for adding poly quat?
    Oct 2010
    michigan
    284
    I have a mesh cover.
    Will Poly quat last the whole winter and allow me to open up without a green pool?
    Or would i be better off adding poly quat in the spring couple months before opening?
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: when closing pool, chlorine level for adding poly quat?
    I add it on the closing and try to open early. It seems to be a case of YMMV. It's best to have the pool as clean as possible and balanced when you close it up.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Remember it is thick and needs 24 hours of pumping to get distributed. There are some threads on the use of it and I had found one where chem geek posted the manufacturers recommended process. What I recall was that they suggested you "shock" for a few days at 5-10 ppm first, and then let the FC drop back to normal levels. Based on that I would say you should shock, then when OCLT is passed, let it drop to your normal level then add polyquat and mix for a day, then close.
    But there are more expert opinions that should chime in.
    -sent with Tapatalk 2
