Results 1 to 10 of 10
Thread: Turning green
    Jul 2010
    Longwood, FL
    151
    Turning green
    I am in Orlando, It was above 90 all these time a pool was clear
    Since last 3 days its beeing 85-86 and pool turning green. I am running 8 hours
    salt level is 3200.
    My test
    FC 7
    CC 0
    TC 7
    Ph 8.2
    TA 100
    CH 700
    CYA 32-35
    cl - 5
    br - 10
    What should I do ?
    15,000 Plaster IG Pool
    AquaRite SWG, C1750 Catridge filter
    G3 Vaccum, T-100 Kit
    Jul 2012
    Dumfries & Galloway, Scotland
    296
    Re: Turning green
    Lower your pH to 7.2 and then start the shock process until you pass the OCLT as described in pool school, the higher the pH, the lower the effectiveness of chlorine, during the shock process you should also disable your SWG
    Regards
    Stuart
    Stuart Murray
    Scotland UK
    UK NPPOC
    Aug 2010
    Dallas, TX
    4,052
    Re: Turning green
    That pH may be higher than it reads. With a SWG, your primary focus should be on FC and pH. pH constantly creeps up with the SWG.
    Stuamur's recommendation is spot-on. Make SURE you are at 7.2 before you move on, high FC will make pH impossible to read. You may have to make multiple muriatic acid additions to get pH down.
    You can leave the SWG on if you want, but it has to be turned off when you are ready to perform the OCLT.
    Jul 2010
    Longwood, FL
    151
    Re: Turning green
    Thanks for replies, I will do this & let you guys know :P
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    Re: Turning green
    Certainly adjust the PH to 7.2, but BEFORE begining the shock process, perform the OFCLT to ensure it requires shocking. Given there is plenty FC (7ppm with CYA at 30-40ppm)), I'm not convinced shocking is the answer, but the OFCLT will confirm. What type of green? Is it clear or murky? Any chance you have added copper algaecide recently?
    Jul 2010
    Longwood, FL
    151
    Re: Turning green
    My Ph is now under control and water turning Blue again.
    For Stabilizer what should I buy and from where any suggestions !!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    Re: Turning green
    Stabilizer can be purchased at your local pool store or walmart...just make sure the active ingredient is 96% or higher cyanuric acid. So after you adjusted PH the green went away. without shocking?
    Jul 2010
    Longwood, FL
    151
    Re: Turning green
    I shocked with bleach, sorry I did not mention in my post.
    Re: Turning green
    Quote Originally Posted by RobbieH
    Whats the most effective way to reduce your pH?
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    Re: Turning green
    Quote Originally Posted by Emilio.Largo
    Welcome to TFP...Muratic acid
    Take a read through pool school. Button is on upper right of this page.
