Thread: Question about polyquat 60
    We are getting ready to close our inground pool. We have Swimtrine Plus algaecide. Is it okay to use this as an alternative to polyquat 60?
    13x23 ProSeries AG Pool
    SandPro .5Hp Filter System
    AquaPro Pro 500 50k Heat Pump
    30,432
    Re: Question about polyquat 60
    what is written on the label? If it's not poly 60, it is probably safe to assume it is not as good.
    Poly 60 seems to be about the best.....some folks simply elevate to shock levels of chlorine and do not use algaecide. I do not cloes so have no educated opinion either way.
    Oct 2012
    209
    ....and definitely don't use it to close if it contains copper.
    24' round above ground, 13500 gallons, vinyl liner, 18" Sand Filter
    Jun 2007
    New Jersey
    653
    Oh, yeah, it's copper:
    Applied Biochemists Swimtrine Plus Green and Mustard Algea Killer 406103 Swimtrine Plus is a highly concentrated copper based algaecide especially designed to kill mustard and green algae. When used regularly, it also prevents the regrowth of all types of algae. Swimtrine Plus contains 9.3% active copper content - making it Americas most concentrated fast-acting algaecide. Features: Triple chelated copper formula stays active and provides algae control between treatments
    From:http://www.amazon.com/Applied-Bioche.../dp/B004ECI3JA
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    mdpennin:
    The active ingredient for a Polyquat-based algaecide is: poly [oxyethylene (dimethyliminio) ethylene (dimethyliminio) ethylene dichloride]. Look for a 60% concentration of that ingredient.
    The use of algaecide when closing a pool is a justifiable use of that product, but I would not recommend using a copper-based algaecide. Would encourage you to go with Polyquat 60.
