Thread: Any Experience With Hayward C1750 NOT C17502 or C17502(S)
    happyheathen's Avatar
    Sacramento CA
    225
    Ain't that a kick in the teeth - tearing apart the plumbing looking for an air leak, and it seems the old filter cartridge was the problem. The pump will prime without the cart, looks like old times with the cart installed.
    The filter is 135 sq ft, uses 1 1/2" plumbing (rest of system is 2") and is ancient.
    Budget rules out buying new, so it's back to craigslist. Found a 175 sq ft C1750 for less than the price of a new cart for the old filter.
    After running into the charm of the early Northstar pumps, my radar is up when Hayward's manual does not list the straight 1750, just the 1750s(2), and parts lists show "special" locking knobs and plumbing fittings for it.
    So - is this thing a decent filter, or "you'll need special __________" nightmare?
    Thanks again
    Dave
    Sacramento
    1980's 15,000 Gal IG Plaster; 1 1/2 hp Hayward Northstar; Hayward Swimclear C3025 Cartridge Filter (325 sq ft, nom.); Pentair Legend; Polaris PB4-60; Equipment 40' from pool. p.s.: it's an aye-aye.
    Sacramento CA
    225
    Re: Any Experience With Hayward C1750 NOT C17502 or C17502(S
    Mods -
    This is a dead issue, and, since there is no activity on it, please lock or delete.
    I have another odd-ball (but cheap!) filter to discuss. This one is in the garage and appears to need a bleed valve, plus a part which looks like is is supposed to be removable isn't. Someone forgot to lube it.
    Dave
    Sacramento
