Thread: Poor planning - frost threat overnight
    Oct 2012
    Central New Jersey
    100
    Help TFP! I've lurked around for a couple weeks around Pool School and what not, getting my bearings.
    I have an above ground pool that came with the house that I just purchased. First pool,so lots of learning.
    Forcast calls for temps in the low 30s tonight. My pool isn't closed yet... should I leave the pump running overnight? or better to shut it off to prevent damage?
    I have a Chlorease SWG, for what it's worth. Oh TFP, please help this noob before expensive damage occurs.
    15K AG, w. Chlorease SWG; 150 sqft cartridge (ClearwaterII); Two Speed pump, seems to only work on one speed; less than 10 yrs old; partially decked.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Poor planning - frost threat overnight
    Yup...let it run overnight. If in northeast, it's forecast to be above freezing by 9 am,...should be fine
    Oct 2012
    Central New Jersey
    100
    Quote Originally Posted by dmanb2b
    thanks for approving and replying. i finally found a pool store open and they also assured me it'll be okay. yes, NE; Central NJ, more specifically.
    i'll be here often - i have zippo knowledge in this area.
    Aug 2010
    Dallas, TX
    4,052
    Low 30s are nothing. It takes a lot of therms to move the temps of a pool. If you have a timer, just set it to fire up around midnight and let it shut off around 6 AM. No biggie. But, really, you don't have to run it at all. I don't close my pool and even in the teens (with the pump running) it is not an issue.
    Oct 2012
    Central New Jersey
    100
    thanks everyone... going to try the closing today... working on cleaning up all the debris... pool hasn't been used about 75% of the summer. will post another topic w. photos
