Results 1 to 16 of 16
Thread: Opinions on a getting more sparkle
    Jul 2012
    Dumfries & Galloway, Scotland
    296
    Hi I have recently started looking after an 28,000 ImpG indoor, in ground, liner pool. The liner itself is a preculiar green and turquoise colour, which really hurts the look of the water, I've got it all well balanced and happy but cannot get a real nice shine on the water, some angles it looks good, whilst others the green liner transmits a rather dulling effect on the water.
    Last Test with Palintest 7100 Photometer:
    FC 4.35
    TC 4.60
    CC 0.25
    pH 7.54
    TA 118
    CH 200
    CYA 34
    Temp 27c/80f
    Calcium Hypochlorite Granular & Tablets used for disenfection Sodium Bi-Sulphate for pH regulation.
    I'm just not happy with the green tinge the liner gives the water, it's not organics in the water before anyone asks, it's simply the effect of the colour of the liner, I was considering the possibility of using borates, but I don't believe it is available at the supermarkets in the UK, and don't know if it would assist in getting a further shine to the pool water, I have found what I believe to be it but can someone confirm if it is simply Boric Acid I would need?. I also realise that the CH level is not needed in a liner pool.
    Any opinions would be of assistance! If I remember I will take a picture and post up.
    Stuart Murray
    Scotland UK
    UK NPPOC
    Jul 2012
    296
    Re: Opinions on a getting more sparkle
    Forgot to add I have been using Aluminuium Sulphate tablets, which has clarified and given some sparkle.
    Regards
    Stuart
    Stuart Murray
    Scotland UK
    UK NPPOC
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Yes, You can use Boric Acid, It cost a little more than Borax, but is easier to use. You don't have the PH Rise and you don't have to use MA to lower it. I've used both Borax and Boric Acid. I've got extra Boric Acid and it's the way I'll go in the future.
    I can't comment on the Aluminum Sulphate.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    I believe boric acid/borates are banned in Europe, unfortunately. Not sure if that affects the UK or not. You may have a tough time finding some, just so you know.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Assuming you have passed the OFCLT? I know you said not to ask, but do want to confirm. Secondly, what is the pump/filter set-up...perhaps increasing pump run time could help give your water a more "polished" look? Otherwise the numbers do not look too bad at all.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    What kind of filter do you have?
    Jul 2012
    296
    I should of anticipated those questions!
    It's a Sand Filter with a run time which has been increased to 4 hours per day, which calculates a 1.75 turnover (best guestimated)
    The OCLT has been passed several times
    I'm unsure if borates have been banned or not but Boric Acid is readily available via sites such as eBay.
    Photos attached, which were taken today at the same time, you can note that from some angles the green coming through from the liner, with other angles the water looks just fine and blue with a nice sparkle.
    Regards
    Stuart
    Stuart Murray
    Scotland UK
    UK NPPOC
    Jun 2012
    Mint Hill, NC
    2,589
    First I would crank up the filter time to 24x7 for a few days to see if that makes ANY difference. If it does, then maybe up the filter time overall a bit (not 24x7).
    Next, since sand filters can only get objects down to about 20 microns, maybe you should explore options to get smaller objects filtered. One option is to add DE or Cellulose DE substitute to the filter to grab some additional stuff. Another option would be to add slime bags on the returns for a few days. Either of these approaches could get you an improvement over the 20 micron filtration - perhaps down to the 1-2 micro level - humans can't see stuff smaller than about 40 microns but the overall impact of smaller particles MIGHT be duller water.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    I'm, in agreement with UWV, especially on the increased run time. Pool filter type DE added to the sand filter would be good if it is available. Although I still do not know your pipe size and pump type, it is very unlikely that a 4 hour run time would result in 1.75 turns. Even at 100GPM it would take 4.5-5 hours for a single turn.
    Jun 2012
    Mint Hill, NC
    2,589
    Now that I see it - the water looks slightly hazy to me.
    Jul 2012
    296
    Thanks for the feedback, perhaps I didn't explain myself sufficiently, It is already clear, sparkling water, the photos just don't do it justice to be honest, and are to demonstrate the effect the liner has on the waters look. Basically I am realistically looking for options too override the green effect of the liner on the water ie make the water more blue.
    As for the pump run time, I have experimented with non-stop runs before during shocking, and am satisfied that the run time is sufficient.
    Can any pool users who have experience of borates and without comment on the colour change before and after? It will certainly help give the water more sparkle, but queery if it will reduce or increase the depth of colour to the water.
    Regards
    Stu
    Stuart Murray
    Scotland UK
    UK NPPOC
    38,521
    I do not recall reading that the borates change the color of the water ... I thought it might just catch the light better to sparkle more. Being an indoor pool ... maybe it is the lack of sunlight that reduces your sparkle.
    I do not think you can change the water color without changing the liner.
    Jul 2012
    296
    Apologies **** for not answering your question re the pump, I had to go check the plate again! It's an Astral Victoria Plus 3hp, I searched again online and found 34m3/h@10m head which equates to 3.74hrs per turn so my maths was off before with roughly 1.06 turns per 4 hour run. As that's the max flow rate I would imagine it to be close enough as the head on the pool is more like 7 metres.
    Stu
    Stuart Murray
    Scotland UK
    UK NPPOC
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    That's what I was thinking, also.
    Jun 2012
    Mint Hill, NC
    2,589
    ...there's always dye. Lol
    -sent with Tapatalk 2
    Jul 2012
    296
    Quote Originally Posted by UnderWaterVanya
    Ha ha, just copy Chicago's river St Patricks Celebration in Blue
    Stuart Murray
    Scotland UK
    UK NPPOC
