Results 1 to 10 of 10
Thread: Unknown pool part
    Jun 2012
    St Pete FL
    45
    Unknown pool part
    HI I would love to post a pic of a part I found in with the pool supplies I acquired but it tells me the file is to big. Hoping if I can describe it good enough someone will tel me what it is and its purpose.
    It is clear, hard, acrylic plastic, reminds me of clear PVC. It is in the shape of a right angle/elbow. On one end it has a u shaped area that looks as if the vac. hose attaches there. Inside of it there is a mechanism with a tight spring and black plastic disc that occludes anything from getting through it to the other end of the elbow. ??????
    5,000 gal Fiberglass paper cartridge filter, autochlorinator, BBB
    20,000 gal Pebble Tec paper cartridge filter, BBB
    15,000 gal Pebble Tec, DE filter, autochlorinator, BBB
    20,000 gal Pebble Tec, sand filter, BBB
    Apr 2010
    Buckeye, AZ 85326
    619
    Re: Unknown pool part
    Some type of check valve?
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    38,272
    Reduce the size of the picture in Paint or picture manager. Or post it on Photobucket and post the link.
    Sounds like a check valve to me as well.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Here's a tutorial on posting photos using Flickr.
    How to add pictures to a post (full guide with screenshots)
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    Jun 2012
    St Pete FL
    45
    OK got it, maybe I can get pics up here now. I know it will make it much easier to ask you all questions.
    So why would they have a check valve but not have it on anywhere? Do they have some that you take on or off?
    22,548
    A picture will definitely be worth a thousand words in this case.
    Without a picture, I'm betting it's a flow indicator for a suction side diaphragm cleaner - water flowing past the gate gives you an indication of too low / medium / too high flow for the cleaner's bumping action.....
    Mine got stuck halfway up a wall and sounded like a bass drum, until a neighbor called me at 0130 hrs to complain..........
    24 foot AG Vinyl, 10 year old wall, 1 year old liner
    Hayward 240T Sand (free!)
    Hayward 1.5 hp pump (free)
    BBB just ROCKS!
    May 2012
    Montville NJ
    545
    Quote Originally Posted by sbn56
    That was my guess as well. You would only use it when running the cleaner. It mounts in the skimmer bottom and the cleaner hose would attach to the other end and go out the skimmer door. In theory they work as describerd, some also have a hole in the side with a spring loaded door in it so that if the suction is too high the door opens and allows the unit to draw water from the skimmer rather than all through the cleaner diaphragm.
    Mine is touchy as well. too low and it just lays there. Too high and it climbs out of the water. The "just right" pressure is in a small range.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    Mar 2011
    Scottsdale, AZ
    406
    I believe this is what you are describing.
    http://www.inyopools.com/Products/07501352033438.htm
    It is a vacuum gauge that comes with a Navigator to set it up.
    You plug it into the last hose, then attach it little U piece back to the hose near the wall outlet.
    This allows you to run back and forth to adjust a valve and get the ideal flow prior to plugging in your vac.
    Jun 2012
    St Pete FL
    45
    @ just a PB You are exactly right. That is the exact piece I have. THANKS especially since I never got around to getting a pic posted.
    Thanks everyone
