Results 1 to 11 of 11
Thread: New Pool First Fill numbers
    Dallas
    51
    Ok my pool finished filling up last night and they are coming to start the pool today. I used my test kit and pulled these start up numbers.
    FC = 1
    CC = 2
    PH = OVER 8.2 the pink color was much brighter than the meter.
    TA = 80
    CH = 150
    CYA = Could see dot all the way to the top of the tube.
    Greg Watson
    15,500 Gallon Freeform IG Martinique Luna Quarts Pool, Jandy CL580 Cartridge Filter, Jandy Stealth Pump, Rainbow 320 Inline Chlorinator and Polaris 280 Pool Cleaner
    38,345
    Re: New Pool First Fill numbers
    There is no CYA in tap water. So if you have not added any (either liquid/ powder form or dichlor or trichlor), then it would be zero. BUT, are you using the Rainbow? If so that is adding CYA, you need to keep very good track of the number of tablet you add so that you know how much the CYA is rising. Eventually, when the CYA gets to 30-50ppm, you will need to stop using the pucks and switch to liquid chlorine.
    I hope whoever is starting your pool does not add too much CYA.
    Post up a full set of test results at least an hour after the "start-up" the pool so that we can see what your should further adjust.
    22,551
    Just to add to what JB said, if you're going to be using the tablet feeder I'd strongly request that they not add any stabilizer (CYA) at all. Infact, I'd almost insist on it. It'll rise fast enough on it's own by using the tablets. And we've seen where the PB adds many lbs on start up and the CYA started out way too high to begin with.
    Dallas
    51
    They started the pool tonight and I wasn't here when it happened so I have no idea what they put in. I will post new numbers tomorrow morning. I am worn out tonight
    G
    Greg Watson
    Dallas
    51
    OK here are my numbers this morning and my Calcium has me worried.
    PH - is under 6.8 (To be expected there is a ton of acid in the pool right now for the plaster)
    FC - .5
    CC - .5
    TA - This test STARTED off red it never turned green
    CH - 370 (Should I be concerned?)
    CYA - 0
    Greg Watson
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    pool-school/pool_plaster_start-up/
    -sent with Tapatalk 2
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,404
    Your CYA will need to be tested in about a week, it will not register on a test for the first few days after being added to the pool. Test the CH of your fill water and be sure to swirl the test vial well between drops. If the CH of the tap water is significantly lower than the pool then test the pool water again.
    Love TFP? Become a
    TFP Supporter!
    Dallas
    51
    They are neutralizing the acid today and I will pull new numbers. I am getting thier pool school tomorrow at noon.
    Greg Watson
    38,345
    Quote Originally Posted by Watson
    Take that with a grain of salt ... I would trust the Pool School you find here. That said, you may need to follow some of their instructions for warranty purposes.
    Dallas
    51
    exactly I have to go through all this just to get free and clear with my warranty in tact. I am most interested in the parts about using the pump more than testing the pool.
    They came this morning and my numbers three hours later are as follows:
    FC = 2.5
    CC = 0
    PH = 7.2
    TA = 70
    CH = JUMPED UP TO 450 (***)
    CYA = 40
    Greg Watson
    30,426
    450 CH is a bit high but still manageable if you watch your pH......keep it in the low 7's.
    If CH goes over somewhere around 550, I would begin to replace some water.
