Results 1 to 10 of 10
Thread: Outdoor kitchen build questions
    We are planning out outdoor kitchen/ gazebo area and are in the planning stages.
    At 1st I was going to go 2x4 and fire proof with cement board but I see the grill still need a insulated liner to be fireproof. Is there any other way around this and be safe? Looks like that alone would run in the $800 range.
    Also looking at aluminum framing but where can one be purchased? I only see companies that will install them but I don't need that. Would local machine shops be the best bet?
    What's the downfall to each?
    And what price would I be looking at for a aluminum frame only? Probably 30 or so feet of cabinet one grill place and maybe 4-6 doors and 2-3 drawers.
    Wanting to make a u shape kitchen with grill on left side, tv center of u , and fridge, ice maker and sink on the right.
    18x36 Grecian Vinyl; 8' Roman steps w/t 2 spa jets; cozy cove w/t 6 spa jets; 2 MD, 1 Skimmer, 3 returns; Hayward Ecostar, 30" Ranger sand filter; Hayward color logic 4.0 LED light; Hayward aqua logic; 2" PVC pipe 4 Jandy Valves
    Aug 2010
    New Caney, TX 77357
    184
    Re: Outdoor kitchen build questions
    Should not use wood framing in the grill section, too risky with regards to fire hazard.
    If you don't want to make your own frame out of metal studs you can buy frame "modules" from the BBQ Coach. Would cost a lot more than a complete DIY but also faster and easier for that phase of the build. You would complete the frame build by attaching the modules to each other. He has standard modules and will also build custom to your specs. I am not endorsing him or his product but it is an option to simplify the build. There may be others out there that offer similar services but this is the only one I know of off hand.
    http://www.bbqcoach.com/modularframekits.html
    20K gal, inground with attached spa, pebblefina plaster (bella blue), flagstone coping, moss rock waterfall, Sundek - Indian wheat, (2) Jandy PHPM2.0 (filter pump and waterfall), Jandy DEV60 DE filter, Polaris 280 pool cleaner, Polaris Halcyon PB4-60Q booster pump, Polaris 1.5 HP Air Blower, (2) Jandy WaterColors LED lights, Jandy LXI400P Heater, Jandy AquaPure PLC1400 SWG, Jandy AquaLink RS PureLink Controller and PDA.
    Your best bet is to use metal studs, which can be purchased from most home supply shops. They are fairly cheap and easy to use! Draw it up first on paper to help calculate exactly how much you need. We build 90% of ours this way. Then face with cement board. Then tile, stucco, ect...
    PremierPoolProducts.com
    Premier Pools and Spas | Omaha, NE
    Stanger General Contracting | Omaha, NE
    Swimming Pool Design/Build Specialist | Consultant | Repair | Parts | Service
    Certified Warranty Station for Pentair | Hayward | Zodiac/Jandy | Aquabot | Polaris
    simple rectangle, stacked blocks, minimal cutting and concrete top
    [attachment=1:2gnub5bh]patio2012.jpg[/attachment:2gnub5bh][attachment=0:2gnub5bh]patio stools 2012.jpg[/attachment:2gnub5bh]
    17,000 gal inground
    vinyl
    swg
    3hp 8 returns
    heat siphon heat pump
    4knights's Avatar
    NE Kansas
    419
    Quote Originally Posted by mikeginder
    nice job!
    My concern would be soil conditions below the grill if using only concrete blocks. That's a lot of weight and if the soil is of clay composition it will likely shift during periods of rain/drought unless a proper base material was compacted prior to the stones being stacked for the kitchen.
    Wood(even fire rated) is not something you want to use as the heat/cool cycle will still degrade the fire resistance of rated wood.
    Galvanized or aluminum studs are easy to work with (although sharp- wear gloves) and a can be found at almost any hardware or big box store. Some stores even have stucco classes or wil provide one if asked.
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    Quote Originally Posted by 4knights
    nice job!
    You are right, that kitchen part WAS built on tamped ground and stone. Its now on a concrete slab. but the first one only took me a day or 2 to build...
    17,000 gal inground
    vinyl
    swg
    3hp 8 returns
    4knights's Avatar
    NE Kansas
    419
    I love the tractor seats, can't find them around here as the farmers still use them on the tractors
    e- bay reproductions, used swivels welded to steel plate, welded to seat, welded to box steel
    17,000 gal inground
    vinyl
    swg
    3hp 8 returns
    Riles_J's Avatar
    Nashville, TN
    218
    Mike,
    I need to know more details about those seats as well. I didn't quite follow your quick description. Can you offer a little more detail of your materials and maybe a few closer shots. I love those and they are what I originally wanted to put at my outdoor kitchen. Instead I ordered some wood stools that made it one season but I don't expect they will make it another.
    Riles
    16x32 IG vinyl, 19,000 gal, 1.0 hp pump, sand filter, 2 returns, 1 skimmer, diving board, slide
    Quote Originally Posted by Riles_J
    Mike,
    Riles
    i bought 6" x 6" metal swivels, had a metal guy make 7" x 7" sq. 1/8" thick metal plate and 8" long 4" sq 1/4" thick box steel, all welded together. Box steel slips over 4 x 4 treated post ( i didnt even fasten them, although i had holes drilled in the box steel) The post slide into plastic sleeves that are in the concrete.[attachment=0:2cu3vurn]tractor seat.JPG[/attachment:2cu3vurn]
    17,000 gal inground
    vinyl
    swg
    3hp 8 returns
