Results 1 to 8 of 8
Thread: Green water inside ladder legs
    Jun 2011
    Northern Maryland (near Delaware)
    170
    So when closing I pulled the ladder out, it is a Confer or something like that plastic ladder that you put water in the legs to stop it from floating. When I pulled the ladder the water that was in the pool dumped (outside the pool) and was green as anyhing even though pool was clear. So I was thinking next summer using my drill pump to pull the water out of the ladder legs every week or so and refilling. Or maybe add some bleach mix to the ladder leg and fill. Any one else ever experience this? Suggestions?
    15'X30'X52" AGP AquaSports Grande Buttress Free (10,620 Gallons), Hayward Dreamline S190 W Zeobrite, 1.5 HP Hayward PowerFlo LX, AquaLuminator Light+ fountain attachment, Pool Rover, Tf-100 test kit, Speed Stir.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: Green water inside ladder legs
    Is the water in the legs able to mix with the pool water or is it completely isolated? If isolated can you fill with gravel and keep the water out?
    - Sent using Tapatalk
    30,421
    We used to have "basketball goals" that had a water filled base. That base let in just enough light to let algae accumulate and get nasty inside. I filled each base (probably 5 gallons) and added maybe 1/2 cup of bleach.....they were algae free for that whole season.
    I see no reason why you couldn't do the same with the ladder(s).
    Jun 2012
    Mint Hill, NC
    2,589
    Interesting - do you think the initial bleach just killed off the algae cells present and then being sealed it did not get back in or did the chlorine maintain over the year due to the low light?
    30,421
    Guessing, but I think that's it. They were a fairly dark blue plastic so allowed very little light.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    I have a confer step for our pool. They should be filled with pool filter sand. At the end of the season I remove the handles and pour a cup of bleach (one on each side) and rinse with garden hose to distribute, then reattach the handles. Looks fine after 4 years. I have also drilled four small holes at the bottom of our step so that they drain and water does not sit in the steps over the winter...small enough so that the sand sand doesn't pour out :>)
    Jun 2011
    170
    Quote Originally Posted by UnderWaterVanya
    completely isolated, fill holes are at top, ladder is white plastic, I am thinking pool sand or gravel, with a little bleach for good measure. If I add Sand I guess I will plug somehow with a rubber plug and keep dry??
    Thanks
    Jun 2012
    Mint Hill, NC
    2,589
    It would be interesting to sample the water at the end of the season for chlorine.
