Thread: pump wont come on but cover is on pool
    May 2012
    tn
    34
    We have an in ground pool and my mom had a cover put on it a couple of weeks ago. We have had a lot of rain but the pump has been off for weeks so today we went to turn the pump on and it wouldnt come on. She was going to backwash some of the water out since the water level is extremely high. Any ideas as to why the pump wouldnt come on? This pool has never had a cover before but we have neglected it over the last couple of weeks. Intended on winterizing it this weekend.
    16x32, 20k gal, IG, vinyl, hayward sand filter model S244T 24in, 1.5hp
    4knights's Avatar
    NE Kansas
    419
    Re: pump wont come on but cover is on pool
    When you say she had the cover put on, was this a company that did it? Did they Close the pool for winter? Call them first to find out. Then -----
    Things I would check:
    Is the pump connected to the plumbing, are the valves turned off, are there plugs in the returns and skimmer.
    Lastly if pump was connected and no plugs in returns or skimmer then I would check the breaker to ensure there is power at the pump.
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    May 2012
    tn
    34
    Sorry should have been more clear. Pool is not winterized still open but the cover was put on by a company a couple of weeks ago but nothing else has been done. Really cover has nothing to do with it. Pump hasnt been turned on in about a month. When I turn the pump on it just hums but doesnt do anything else. I checked the impeller but cannot turn it by hand. I read somewhere it could be the impeller (clogged) or the motor. Dunno what else to do. The unit is 5 years old, but I figured they would last longer than that. Am I wrong?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Could be a bad capacitor. Shut power off and see if you can turn the impeller by hand through the pump basket. If so, a bad cap is likely. About $20 and most pool stores or motor shops will have it.
    May 2012
    tn
    34
    Cannot turn impeller by hand, what does that mean? Bad Pump?
    SW Indiana
    9,199
    Quote Originally Posted by claymerica
    Probably a bearing getting ready to go. Sometimes you can free it up enough to work for a while. What pump is it?
