Results 1 to 11 of 11
Thread: cell Only generates in Service mode
    My cell started to only generate in service mode. Swapped cells , same issue. All lights work. Panel in house works but when I switch it to Auto mode , The low flow light will come on for a sec ( usually stays on for ~30 SECONDS) Then no generator light. In service mode in comes on and all is good.
    22,553
    Re: cell Only generates in Service mode
    What's the temp of the water?
    84 degrees. Salt is at 3600 ppm no alarm lights on panel . It should be just fine. It just wont generate in Auto mode .
    22,553
    Have you tried jumping out the flow switch?
    all ive tried is swapping cells, And switching to service Service works great,but i want it to work on auto in the house.
    Also I have no idea how to do what you suggested..lol
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Is that normally open or closed?
    - Sent using Tapatalk
    22,553
    The flow switvch is normally open and closes under flow.
    What swg do you have?
    Jun 2012
    Mint Hill, NC
    2,589
    [quote=Bama Rambler]Have you tried jumping out the flow switch?
    Quote Originally Posted by swooperdave
    Quote Originally Posted by "Bama Rambler":3bygpger
    [/quote:3bygpger] Based on Bama's reply to my question I think you would simply find the flow switch and jumper from one side of it to the other causing it to electrically seem as though you had flow. You should verify it is Normally Open and Closed when flow is present first, and part of the way to do that is to answer his question below:
    All of this is just for the purpose of verifying if the flow switch is indeed the problem - if not then you would want to remove any jumper you add for testing.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Try disconnecting the comm wire between the generator and the automation. It is a four wire connection, usually connected to a bus that you can just unplug at either end. My guess is that the automation is telling the generator not to come on, perhaps it is turned down, and when you switch to service, the automation gives control back to the generator, and starts to work.
    Factory Warranty Station for:
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    Are the flow rates the same in auto and service? Also, for my cell to come on, I have to have it in pool or spa mode. This is on my easytouch 8.
    14.5K gal Plaster IGP, Intelliflo VS, EasyTouch 8, SWG, IntellipH, Clear and Clean 420 Cartridge Filter, Attached Spa, H400IDL2 NG Heater
