Results 1 to 7 of 7
Thread: AQUA LOGIC GOLDLINE CONTROLLER
    I have a Aqua Logic controller and now it's not generating any chlorine. I had salt cell checked and it is fine. Controller is showing:
    Chlorinator off No cell power
    Salt level 0000
    check system no cell power 2
    reset light is on
    Anyone have any ideas ast to what could be the issue? The pcb board looks OK visually
    Thanks Scott
    Christian's Avatar
    Jul 2012
    Sacramento, California
    304
    Re: AQUA LOGIC GOLDLINE CONTROLLER
    Hey Scott, try pulling out the PCB board and looking at the back of it. There is a spot on the back of the board that frequently burns out and if so you should be able to see the damage.
    Mar 2011
    Scottsdale, AZ
    406
    Thanks Christian I will try pulling the board in the morning.
    OK just as you suggested. When I looked at the back of the pcb borad it was burned. So I soldered and I did get readings at first. Now it says salt amps to high chlorinator off. It always seems to read about 800 ppm more than Leslie. Is there something I can do short of dumping water to lower salt readings?
    Mar 2011
    Scottsdale, AZ
    406
    What is your actual salt amount in your pool?
    The actual salt is 3100 per Leslie the controller shows 3900 to 4000
