Results 1 to 12 of 12
Thread: Flexible vs. Hard Plumbing?
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    I have a sand filter with a multiport attached to my pool plumbing using hard PVC. The pool was built by previous owners and seems to have had a few repairs over the years. The plumbing as it is does not really permit removal of the multiport to do any kind of cleaning of the sand or inspection of the laterals etc.
    Because of this I started wondering if it would be possible to replace some of the hard pipe with flexible pipe like you see on some AGP's. But - things work well as they are - I don't want to solve one problem and cause another. Is there a disadvantage to the flexible pipe? Is there a better way to make this more serviceable?
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Flexible vs. Hard Plumbing?
    You can use unions with hard pipe.
    http://flexpvc.com/cart/agora.cgi?cartl ... I_Need.htm
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by bobodaclown
    I was aware that could be done - the lower pipe on the front in the picture below has been chopped and repaired a few times and is going to need replacing a bit further back if I do that. Does that give enough clearance to lift out the entire valve assembly without stressing the hard sections of pipe beyond the unions?
    Apr 2011
    Murrieta, CA
    2,360
    It would really depend on where you put the unions. If you put them a couple of inches from the multiport, you'll have enough room to disconnect the multiport and inspect everything. The only glitch I see it is the waste line, but even that should be doable. Looks like you'll need 3 unions.
    Jun 2012
    Mint Hill, NC
    2,589
    Oh I see - essentially leave the existing connections hard plumbed to the multiport, and add the unions back a bit. I can move the waste line back it's not that big a deal - it's only resting on the ground not attached to anything else really.
    happyheathen's Avatar
    Sacramento CA
    225
    Unions are large fittings and you seem (to my eyes) to have some close clearances.
    First, get the diameter of the fittings you plan to use and make sure you have the clearance before cutting lines.
    I didn't, and have a whopping 1/2" between the union's nut and the pressure (return) line.
    I use a strap wrench - if you don't have one, pick one up when you get the unions - ordinary pipe wrenches will not work on the unions.
    The little Sch 40 (white PVC) 1 1/2" is a bit over 6" in diameter; the sch 80 (gray PVC) 2" is about 8".
    Dave
    Sacramento
    1980's 15,000 Gal IG Plaster; 1 1/2 hp Hayward Northstar; Hayward Swimclear C3025 Cartridge Filter (325 sq ft, nom.); Pentair Legend; Polaris PB4-60; Equipment 40' from pool. p.s.: it's an aye-aye.
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by happyheathen
    yikes!
    - Sent using Tapatalk
    Sacramento CA
    225
    My bad - actually, the diameters are 4 and 5", respectfully. The 1/2" stays.
    Dave
    Sacramento
    38,371
    I had to offset the unions a bit to have them fit on the horizontal pipes coming out of my valve as well.
    Of course you could always put the unions on the vertical pipes as well ... but you would loose the ability to easily re-torque the screw in fittings if they ever started to leak.
    Jun 2012
    Mint Hill, NC
    2,589
    I'm not following this - care to elaborate?
    38,371
    If the union is on the horizontal pipes, you can unscrew the union and then you would be able to unscrew the fittings into the multi-valve or tighten them and then just screw the union back together. There is no alignment requirement in the union.
    If the union was on the vertical, you can not turn the pipe and fitting still attached to the valve because then the vertical pipe would no longer be vertical and not be in line with the other half of the union.
    I just redid my pad and both of the multivalve screw in fittings are dripping. But since I put the unions on the horizontal, I can either loosen the union and tighten the screw fitting. Or remove the fitting and recoat with pipe dope and try again. The union will still be in line.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Jun 2012
    Mint Hill, NC
    2,589
    Got it - thanks!
