Results 1 to 7 of 7
Thread: Redo Brick Coping
    Redo Brick Coping
    Our new pool was just completed however we have been advised by the paver installer that they need to redo the brick bullnose coping. When initially done the installers grouted the coping while others were cutting pavers for the deck. They believe dust got into the grout, grout is very discolored. They want to take out current brick coping and install new coping and grout. My concern is damage to our pool. Would we need to empty the pool? They said we would just need to lower the water about a foot. Wouldnt the dust be a nightmare? I just don't want to compound onto an existing problem with more problems. Any advice would be great!
    Pool Size=23,000 gallons
    DE Filter = DNS 48 sqft
    In ground pool
    Re: Redo Brick Coping
    Here is a picture of the discolored grout. Also, it started to rain before grout was dry so the installer is not sure if this caused the discoloration as well.
    In ground pool
    Apr 2012
    Klein Tejas
    249
    If you like the brick, why don't you attempt to clean it first. If that doesn't work perhaps use a dye to change the color.
    There's a house close to me that had their tile replaced and instead of replacing the 40 year old concrete coping they had it dyed a darker color.
    Pool is DONE!
    Pentair Intelliflo VS3050
    Pentair Easy Touch 8 + actuators + swg
    Pentair IntelliPH
    Pentair 400btu HD heater
    3- Jandy WaterColor LED's
    Hayward C5030 525sqft cartridge filter
    Waterway spa blower
    I say drain the pool...makes life simple..
    BTW... I did not notice any sealing between the coping and the deck...You'll be sorry in a few years...i found out the hard way, costing thousands in repairs.
    ~12,000g IG pool w/ Spa and sun shelf, Jandy rs8 automation, Jandy CL340 filter, 2 Jandy Stealth pumps, Aquapure SWG, Ultrapure Ozone and Aquacal heat pump...
    Masong, what do you mean by sealing?
    In ground pool
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    There is no reason to fully drain the pool and depending on your water table may even cause more harm than making things simple
    Quote Originally Posted by sunngurrl
    I found out the hard way... Lets see if I can explain
    The coping is applied to the pool wall (called beam wall)
    Your deck, where it bumps up to the coping, should be a complete seperate enity from the pool...( it should also be sealed to keep water out of that area)
    A
    This is obtained by an expansion joint between the two..Allowing them to move, heave, or expand as needed without the deck pushing against the coping and causing it to break its bond.
    What type of decking do you have?? Concrete, pavers over a sand fill , or what ???
