Thread: pucks without CYA?
    pucks without CYA?
    is there such a thing as a 3" puck that does not have CYA in it?
    i am looking at going BBB and testing the water, and skimming daily and the pucks seem so easy (except for the CYA issue). if they only made one without it i would feed a lot better about using it. my CYA levels are below 20PPM so i think i am safe to use it for a few more weeks. but after it's gone i would like to stay with the pucks but only if i can get CYA free ones.
    tks,
    Mc5
    Southern Girls Pool- In ground, 18X36 vinyl liner, approx 27K gallons with sand filter, booster pump for polaris, and Jandy gas heater in Mississippi
    Guest
    in a word NO, the reason is that the chemical, trichlor, is the slowest dissolving form of chlorine so it is effective in a puck. The next slowest dissolving chlorine is cal hypo which does not have CYA BUT it does cause calcium hardness to increase. It has been made into capsules or tablets to be used in a skimmer (CANNOT BE USED IN A TRICHLOR FEEDER OR FLOATER>>>IT CAN EXPLODE IF YOU DO!!!!!)However, most people who try them are not very happy with them since they only last for a short while, maybe 2 days and they are gone!
    Mar 2007
    San Rafael, CA USA
    12,082
    Mc5,
    Consider using The Liquidator talked about in this thread. You'll only need to refill it once a week with chlorinating liquid or bleach so it's at least as convenient as Trichlor but without adding the CYA.
    Richard
    Quote Originally Posted by chem geek
    Mc5,
    Richard
    Much Thanks!
