Thread: Add some DE to a sandfilter
    May 2008
    South Central PA
    20
    I heard that you could add some DE to a sand filter to improve filtrations
    From what I understand you take a 1/3 of a cup of DE mix with water and add to your skimmer.
    You do this process untill you get a 1psi increase at the filter. Than when you backwash you
    add new DE.
    Please comment if this really works or is a bad idea
    Thanks
    Mike
    Mike
    13,500 gallon AGP, 1-1/2hp pump 150# sand filter
    I do it, I add about 1/4 to 1/3 cup to my filter and it does wonderfully. I actually raises it about 3 psi, but that's not alot. When I backwash I add 1/4 to 1/3 again, until the psi goes back up. It filters better, it filters out algae etc faster, and is just all around better.
    Hurricane Rita did not kill me, but she killed my pool!
    Intex 36'X18'x52" "elliptical pool"/ Hayward 220 filter/1HP pump 14,364 gal, or so
    Yes, adding DE to a sand filter works well. I suggest adding 1/4 cup of DE mixed into a pail of water to the skimmer, give it five minutes to settle down and then check the pressure increase. Repeat this process till the pressure has gone up 1 psi. After the first time you can simply put the correct amount in all at once (premixed into a bucket of water). If you have a skimmer sock be sure to remove the skimmer sock, or entire basket, while adding the DE.
    If you are getting a 3 psi increase in pressure, try using less DE next time.
    Sorry, I am a complete novice....what is DE?
    [i][color=#BF0040]27' x 52"....1.5 HP hayward pump 200lb sand filter.....finally building our deck :)
    D to the E is Diatamaceous Earth
