Thread: Is there a way to seal Sun Deck/ Kool deck? DIY job
    mrmiguelrobles's Avatar
    Oct 2012
    Puerto Rico
    20
    Hi, I recently install my very first pool. Based on being handy and on budget mostly, we tackled the job on ourselves. So far so good, but after we poured the sidewalks and apply Sun deck problems started. I bought the "Desert Deck" (supposedly another brand of Kooldeck) from a local pool supplier. I ask for instructions and they told me that for every bag should be mixed with 8 small 25lbs of marble sand and white cement 50lbs, then apply to freshly poured concrete with a brush then throwel before it hardens. The first batch I only use 4 bags of marble sand instead of 8, second batch tried the original formula. The first batch held out pretty good, but the second started crumbling within a week. I asked around to see if theres a sealer or something that could add more strength and shine to the deck. First batch even it held is very pale and opaque. Also let me know whats wrong with mix. Thanks a lot.
    Peanut Shape Fiberglass, Varies 10-14' X 25' long. 3.5' Shallow- 5.5' deep end, about 7000 gals.
    Splapool 1 HP - 75Gpm Pump and 100Sqf Cartridge Filter.
    DaveNJ's Avatar
    Toms River, NJ
    520
    Re: Is there a way to seal Sun Deck/ Kool deck? DIY job
    There is a sealent for Kooldeck. here's a link.
    http://www.mortex.com/products/kd.html
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    Oct 2012
    Puerto Rico
    20
    Thanks, your link took me to the Kool deck home page, I did some search around and found Protect-A-Deck.
    http://www.mortex.com/products/kpad.html
    I guess that was what you were refering or Im awful getting hints...
    Mar 2011
    Scottsdale, AZ
    406
    The instructions say 10 gallons of marble sand size 20, 1 bag 94 lbs of white cement and 8 gallons of water.
    So it doesn't sound like you followed the right recipe.
    Their website has great videos ect for this.
    Truly this is not generally a do it yourself project, it takes a long time to get the skills to do it right and fast as it has to go over very green concrete.
