Results 1 to 7 of 7
Thread: Small pump I found....
    Jul 2012
    Chicago, IL
    358
    As I was poking around the pool shed to see if previous owners left anything else behind that may come in handy for winterizing, I came across a small water pump.
    (I believe it is this one: http://www.flotecpump.com/ResidentialPr ... 360AC.aspx)
    There is a sticker on it that advises to pour oil into the inlet prior to each use. I assume this would be to lube the impeller? What kind of oil should I use though, small engine oil? Olive oil? Any kind of oil? The manual I found online was silent on this.
    My guess is this would have been used for draining in prep for winter and also to pump water off the cover, agree?
    Dedicated TFPer since 2012 with recommended test kit
    AGP, 30 foot, 21,000 gallons with these homemade islands
    Hayward 150 sq foot cartridge filter, 1HP Waterway pump
    Raypak 400K BTU NG Heater! (Installed 2015)
    Installed in 2006? (just a guess, pool came with house I purchased in June 2012)
    Jul 2012
    Chicago, IL
    358
    Re: Small pump I found....
    Well, since this has stumped everyone I don't feel so silly! I was able to find an instructional video related to this pump and it mentioned the use of mineral oil. That would suggest to me that any type of motor oil might be too thick, so I am probably going to go with vegetable oil or some sort of cooking oil if I cannot locate mineral oil.
    Mar 2011
    Scottsdale, AZ
    406
    Motor oil is not generally something you want to pump into the environment, no matter how small.
    Mineral oil is a environmentally safe product.
    Most any hardware store, many grocery stores, CVS/Walgreen type stores should carry this.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by Pauls234
    Veg/Cooking oil decomposes easily and goes rancid. Mineral oil is available in grocery stores, drug stores, etc.
    Quote Originally Posted by UnderWaterVanya
    I put vegetable oil in mine, it's a similar pump. Mine only holds a very small amount. Going strong 3 years now (runs about 14 hours/yr )
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by Speedo
    YMDV (Your Mileage Did Vary)
    I'm not surprised that it worked - but I'm not recommending it either.
    Jul 2012
    Chicago, IL
    358
    Good to know, now I just hope the pump actually works!
