Thread: how to close a pool? some questions
    Oct 2010
    michigan
    284
    I have already read pool closing in pool school, just have some questions.
    15,000 gallons pool with spa.
    suction side, skimmer and 2 drains at the bottom of the pool.
    return side, 2 pool returns and 6 spa returns and main return in spa.
    1. What do i use to hook my shop vac to the skimmer so it fits?
    2. how do i blow out the main suction drains without water going back into them from the pool? (guessing i turn the valve to suction from skimmer only as i'm blowing it out?) how do i get the pool antfreeze into the main suction drain lines?
    hope qeustion 2 isn't to confusing. lol
    thanks
    steve
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: how to close a pool? some questions
    1. You will probably have to visit the hardware store and find some kind of plumbing fitting that works best and if it's slightly too small you can build up the thicnkess with duct tape. Pool guys actually use a blower (usually called the cyclone vac) and it typically uses 1.5" flexible hosing and I have a fitting on me that reduces it to 1.25 when needed.
    2. Yeah, you kinda got the idea. you blow air into the main drain plumbing until you start to see bubbles coming from the drains and then you quickly turn off the valve for that line to trap the air from escaping and therefore the water can't fill the line since the air can't escape (when you do this keep an ear out for a hissing or sizzling sound of air escaping past the valve which is common, if this happens you can try to put a rubber plug to backup the valve and if that doesn't stop the sound then you are getting into cutting in front of the valve) You don't get antifreeze into a main drain (i suppose it would be technically possible but not really worth while unless you plug the maindrain at the bottom of the pool because if you didn't it would just dilute into the pool._
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Oct 2010
    michigan
    284
    Thanks for the reply, i appreciate it.
    was reading something about a gizzmo? do i use a gizzmo too hook upto the skimmer and find a way to hook up a shop vac to blow out the lines?
    X-PertPool's Avatar
    Exeter, PA
    1,385
    There are 2 kinds of gizzmos the solid kind and the blow through kind. basically a gizzmo is just a threaded plug with a big hollow tube attached. The hollow tube is designed to take squeeze of the winter freeze so your skimmers body isn't getting squeezed. The blow through kind has a small hole that would probably be best suited for an air compressor. I use the solid kind. blow the skimmer then plug it with the gizzmo. Please keep in mind that gizzmo's aren't as good as SP1022C plugs when it comes to sealing. the sp1022c plug will seal much tighter and more torque can be applied to it. Every pool has a different setup but if your MD and skimmer were connected in a way that the backpressure from the MD could reach the skimmer then I would use the sp1022c plug and use something else for expansion in the skimmer like pool noodles, anti-freeze jug with a bunch of stones added etc.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    Oct 2010
    michigan
    284
    thanks for the info, much appreciated. gonna buy both.
    http://www.amazon.com/Gizzmo-MWUG-Skimm ... rds=gizzmo
    to blow it out, can customize it so it works,
    http://www.amazon.com/Hayward-SP1022C-R ... B002EL3YCE
    gonna get that for the plug, can't remember from last year if the pool company used that or the black rubber plug, will have to check the shed and see what they used.
    just checked, they used a rubber plug last year in the skimmer
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Sometimes a rubber plug needs to be used, sometimes the threads in the skimmer are too shallow to use a threaded plug. If you can get a threaded plug to work it's better than rubber in my opinion
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
