Thread: PB Quote
    Sep 2012
    Ramsey, NJ
    15
    PB Quote
    I am renovating my pool and spa in northern NJ. I discussed my problem here http://www.troublefreepool.com/copin...rs-t53531.html
    Pool is 20'x45'. Spa diameter is about 7'. Here's one quote I received:
    Remove existing bullnose paver brick coping and replace - $9,000
    Replaster with Diamond Brite Plaster, exposded stone aggregate finish - $14,000
    Free brushing as needed following plaster installation
    TILE - remove existing tile from pool and spa, install new tile - $5,400
    Install Deco Seal expansion joint - $1,650
    Bondbeam Repair - $900
    Crack Repair on top step - $450
    Replace Heater with Raypack 406 - $3625
    Replace Blower - $500
    Lift and reset pavers that have moved from pool cover anchors & install new 18" anchors - $1,400
    Powerwash Patio and install Stabilisand - $2,200
    Is this quote reasonable?
    40K gallons in-ground, plaster, square pool. DE filter. 1.5HP Hayward pump. 0.5HP Booster Pump. Spa. Brick pavers patio. Mesh pool safety cover.
    Jun 2011
    Long Beach, CA
    2,781
    Re: PB Quote
    I suggest getting a couple more quotes and go from there.
    It's hard for anyone to say if the price is justified or not because we can't see exactly what needs to be done. The quote does seem to be high from just reading, but I can't tell you that it is reasonable or not. One example is the heater, if all that needs to be done is remove the old heater and replace with the new heater, then that price would be high. If he needs to replumb, add electrical, or add a gas line, then the price is more reasonable.
    Sep 2012
    Ramsey, NJ
    15
    Re: PB Quote
    I got a second Quote, but it was kind of broken down differently:
    Spa:
    re-tile and re-plaster spa: $7,500
    Pool:
    Empty pool and discard coping & tile: $1,250
    Install 4x12" bullnosed paver coping : $6,500
    Tile: A new 6 tile band with matching step and bench trim tile will be installed on the pool and autocover
    box chosen from our standard selection.- $5,500
    Interior Finish: Pool will be plastered in a white Marbledust finish with silicone shield additive.-$8,000
    Expansion Joint: Install x4 Deck-o-foam expansion joint and top with grey Deck-o-Seal self-leveling
    expansion joint compound.-$1,500
    Apr 2012
    Klein Tejas
    249
    Re: PB Quote
    Although that's a big pool, it's definately more than we'd pay down in Texas.
    It's hard to say what's normal in New Jersey.
    Pool is DONE!
    Pentair Intelliflo VS3050
    Pentair Easy Touch 8 + actuators + swg
    Pentair IntelliPH
    Pentair 400btu HD heater
    3- Jandy WaterColor LED's
    Hayward C5030 525sqft cartridge filter
    Waterway spa blower
    Dec 2009
    Central Massachusetts
    2,690
    Re: PB Quote
    Quote Originally Posted by nikolaypavlov
    These are REALLY high, and im in massachusetts.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
