Thread: Laars Lite LLD (From ~1997 to 2000) Heat Exchanger Material
    I have a very rusted Laars Lite LLD heater that is nearing a trip to the scrap yard. I pulled the heat exchanger out the other day and saw green (Literally and figuratively)
    Does anyone have a spec sheet that shows the percent copper in the exchanger?
    Here is the model - > http://www.poolcenter.com/parts_heaters ... olstor.htm
    _____________________
    15K IG Fiberglass
    IC40 + Easytouch + Superflow 1 HP 2 speed
    Sherlok 120, MaxETherm 200 HD Heater, Southeast Michigan
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Re: Laars Lite LLD (From ~1997 to 2000) Heat Exchanger Mater
    I've never seen anything from a manufacturer that tells what % of copper is in the unit. What are you trying to get at with regards to this question?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Quote Originally Posted by ps0303
    I am bringing the unit to the scrap yard, and there are various payment levels depending on the copper content of the material. I was hoping to have it to negotiate a higher price
    15K IG Fiberglass
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    It's considered #2 copper. The # refers to how clean it is. So #1 would be real clean and shinny and #2 is dirty. You would need to cut the copper off of the headers, ends, or they will give you even less.
    Paul
