Results 1 to 9 of 9
Thread: quick ESTIMATE of turnover time?
    May 2012
    Redding, CA
    24
    I know, I know, there's no easy answer. I'd just like a reasonable estimate for starting, so I don't go for weeks and weeks after starting with a gross over-estimate.
    So for those of you who have lots of experience, can you offer a starting point for me?
    24,500 gal plaster, 2 skimmers and 2 returns in the deep end (though they join somewhere) for a total of 3 return lines to the pump. Pump platform sits just a few inches higher than the pool. 3/4 HP Whisperflo single speed. Summer temps up to 110F, winter down to 40F.
    Thanks for any educated guesses.
    24000 Gal in ground plaster pool. Pentair FNS 35 DE grid filter. 3/4 HP single speed pump.
    400 Gal Hot Spring spa. Fiberglass.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: quick ESTIMATE of turnover time?
    Quick estimate is 50 gpm, or 3000 Gal/Hr.
    24,500/3000 = approx 8 hours for 1 turnover.
    May 2012
    Redding, CA
    24
    Quote Originally Posted by bobodaclown
    Thank you!
    mas985's Avatar
    Pleasanton, CA
    11,741
    On 2" plumbing the Whisperflo will probably deliver over 80 GPM.
    What size is your pipe size, what type/size filter do you have and what is the filter pressure?
    Mark
    May 2012
    Redding, CA
    24
    Quote Originally Posted by mas985
    2" pipes. Pentair FNS Plus DE filter, 36 sq. ft. Pressure is currently 12 psi (8 psi when freshly coated with DE). If it makes any difference the "Service Factor" on the 3/4 HP WhisperFlo is 1.67.
    mas985's Avatar
    Pleasanton, CA
    11,741
    At 8 PSI, I get around 96 GPM and 11 PSI, around 91 GPM.
    But that pressure seems a little low for that setup up. What size are the eyeballs (diameter)? Also, what size mult-port valve is on the filter?
    Mark
    May 2012
    Redding, CA
    24
    The filter has a 2" slide valve on the side ports (to redirect flow for backwash). I'm not certain what you mean by the "eyeballs." Do you mean the check valves? There are check-valves on each of the returns that have clear covers... these are, again, 2" in and out, straight (the product description, best I can tell, says it's a 2 x 2 1/2"... for example: http://www.zodiacpoolsystems.com/Produc ... Valve.aspx).
    Point me in the right direction for the eyeballs.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Sorry, eyeballs are fittings where the water returns to the pool through the pool wall. Normally, there are eyeballs which can be moved to redirect the return flow. However, not all pools have eyeballs, some just have a pipe that is flush with the pool wall.
    http://www.poolcenter.com/accessories_m ... eballs.htm
    Mark
    May 2012
    Redding, CA
    24
    Aha! Learn something new every day. My pool has 4 eyeballs (I almost said "I have 4 eyeballs), and they are each 3/4 inch diameter at the opening.
