Results 1 to 12 of 12
Thread: Algaecide for closing
    Sad day here in Central PA - Closing the pool
    I like to keep it running as late as I can, just in case we get a warm day - Wed was 80 & we were in it!
    I used to buy the 'kit' til I got hooked up here but now I'm a little smarter. Got a sample and am testing the water next.
    The only Algaecide I can get TODAY is 'Algae Guard 3X' at WallyWorld - I know most of you here use polyquat.
    Is this an acceptable substitute or should I wait and get a 'better' product
    Thanks - You are ALL so helpful!
    JS
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Algaecide for closing
    Just balance your water before you close it. I don't like anything but alg 60%. If you have a tarp cover you won't need anything else. If it's a mesh cover use the polyquat alg 60%. Some people like pool magic spring and fall.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Hi Kevin
    Thanks for the reply - didn't get to it yesterday so I'll try to find the PolyQuat today. Water tested fine, CL was a little high but everything else was in range (19000 Gal SWG pool run by a pool pilot)
    JS
    Oct 2010
    michigan
    284
    I have a mess cover and always open to a green pool.
    what brand of polyquat alg 60% to use? or brand doesn't matter long as it says 60%?
    sorry to tap into your thread
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by smooth2222
    Yes - any brand is OK.
    Tarp cover - no algaecide (I closed yesterday). I also decided to finally get a leaf net, I have a feeling it will pay for itself every year. It caught about 20+ leaves from the time I started draining (immediately after vacuuming) until I was done (small pump, runs about 7 hours).
    Never thought about it before, but that's a nice advantage to using a mesh cover (no soggy leaf gunk). Assuming the water level is low enough.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    It depends on the type of cover you have, if it is a "tarp" or polymer cover that is does not transmit light into the pool, then just adjust the pool pH (7.2 - 7.6) and raise the chlorine to about 15 - 20 ppm; don't need algaecide. As algae is a plant it needs light to grow; if your cover is mesh or let's light into the pool then add algaecide, one with copper is probably the best. Copper levels of 0.5 - 1.5 ppm are toxic to algae and effectively block their growth.
    15-foot above ground pool, Hayward Turbo-Flow pump with sand filter, use liquid chlorine, Metchlor Caddy pool chlorinator; Metchlor Caddy also used for automatically adding muriatic acid; winterize with light and water resistant cover.
    38,475
    We never recommend algaecide with copper in it. Use the polyquat if you are going to use any.
    Copper can just lead to staining of the pool and hair.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Jun 2012
    Lafayette, Ca / USA
    260
    If we WERE to use Polyquat 60, is this one from Leslie's Pools adequate? or is there a better brand that can be had cheaper somewhere?
    http://www.lesliespool.com/Home/Pool-Ch ... 14025.html
    30,000 Gal FIBER GLASS (over Gunite Plaster) Pool, Dolphin Nautilus PLUS Robot, (2) Cartridge Filter System (old), 1/2 HP Pump, Full Sun, Solar Heated, TF-100 Test Kit.
    Mar 2007
    San Rafael, CA USA
    12,082
    The Leslie's product is OK to use. For other options, see the thread which brand of polyquat?
    Wait til the water is blow 60, shock and close. I don't use a cover and wait until most leaves are off trees to I've a good cleaning...shock, wait two days...pull plug.
    Jun 2012
    Lafayette, Ca / USA
    260
    When you say "pull plug", what does that mean? After bringing to "shock levels", you truly don't ever check your levels again all winter? I don't plan to cover ours either.
