Thread: Pool overflow drain.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Hello All,
    I have a 1.5 inch PVC Pipe that is coming out of the ground that I believe is an over flow for the pool. (My neighbor has something similar.) Mine doesn't drain though. I've looked into the skimmer basket there is only one pipe connector that goes to the pump.
    Yesterday, I checked out the main drain (took off the cover and looked) There are 2 connectors one goes to the pump, the other has a threaded cap (Hydrostatic plug?). Is it possible that the threaded cap goes to the overflow?
    What could happen if I remove the threaded cap and it's not connected to the overflow drain? (I'm thinking this could go bad really quick.)
    Any other ideas?
    Qwaxalot's Avatar
    Jun 2012
    439
    Re: Pool overflow drain.
    Quote Originally Posted by bobodaclown
    Hello All,
    Any other ideas?
    If it's a hydrostat (in the drain pot) the part you can see is spring loaded and can be lifted slightly (which will let water out, creating a suction that you'll be able to feel).
    You could overfill the pool and see if water comes out.
    However, if you have a high water table, I think it more likely that the 1.5" pipe goes to a well point for dewatering during construction or repairs (they are usually capped though)
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
