Thread: Pool Light Niche Repair - CMP 25549-500
    Has anyone used one of these, and if so did it work out well for you?
    CMP 25549-500 In Ground Pool Light Adapter
    http://www.c-m-p.com/PDF/Pool/lightrepairfitting.pdf
    My issue is that after at least two refinishes, the bottom clip of my pool light niche is buried in Pebble Tec. Yes, the pool contractor should have caught this and replaced the niche or made some other accommodation for the light, but we're past that point now. The light is basically being held in (barely) just by the top screw and it will not clip in on the bottom.
    I'm thinking about trying this Custom Molded Products item. Any other suggestions would also be greatly appreciated.
    Thanks!
    ps0303's Avatar
    Jul 2011
    FL
    3,526
    Re: Pool Light Niche Repair - CMP 25549-500
    Why not just use the repair wedge?
    Paul
    http://www.gastekservices.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Not sure. I'm looking for people's experiences and suggestions. We can throw the wedge into the discussion too. It looked to me like the wedge would only help with a broken screw thread at the top. My problem Is with the clip at the bottom. The light will not clip and therefore is not flush with the pool finish.
    Quote Originally Posted by ps0303
    Qwaxalot's Avatar
    Jun 2012
    439
    Quote Originally Posted by travelrider
    Aladdin makes a product called "Aladdin ring". It is intended for your problem. They are quite expensive, but do work.
    If you're handy you may be able to use a small chisel and a diamond sanding pad to remove some of the pebble. This is not easy, and may expose the underlying finish.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    Quote Originally Posted by Qwaxalot
    Thanks for the suggestion. The Alladin Ring would be perfect if it came in black. All of my underwater fittings are black in my pool and so this would probably stick out like a sore thumb... I even bought a black ring for my light. Any other suggestions? (Painting the white one would probably not last unfortunately).
    Qwaxalot's Avatar
    Jun 2012
    439
    Thanks for the suggestion. The Alladin Ring would be perfect if it came in black. All of my underwater fittings are black in my pool and so this would probably stick out like a sore thumb... I even bought a black ring for my light. Any other suggestions? (Painting the white one would probably not last unfortunately).[/quote]
    You might be surprised. I've actually painted white return fittings with black fingernail polish and had it hold up.
