Thread: Best way to fix leak at pad
    Nov 2010
    Calera, Al
    271
    The past few nights when I have checks in my equipment pad I have noticed dampness on the concrete under one of the PVC pipes where it comes out of the inline tab feeder. I can feel under the pipe at the connection and it is wet. Suspecting a small leak, This morning when the pump kicked on I was there and watching this area. Within a few minutes a small drop of water formed and dropped to the concrete pad. It is more like a seep and a drop only forms every few minutes, but it is a drop of water, so it is very slowly seeping or leaking water at this connection. It is a PVC glued connection. What would be the easiest way to reseal this connection can I use some epoxy to seal it? Or will I need to cut it out and re do this potion of the plumbing? Even though I do not use it, I do want to keep the tab feeder for when we go out of town. The problem is the PB did not use unions and I think he just glued the PVC into the inlet and outlet of the feeder.
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    30,421
    Re: Best way to fix leak at pad
    Hi. Rob,
    Some folks have reported success with epoxy but i think I would simply leave it alone or cut it out of the system and remake the joints.
    Unless it is forming a pubble that is a constant annoyance, I think I would be tempted to leave it until it got worse.
