Thread: new kind of filter?
    new kind of filter?
    Any one have an expert opinion on using Jeans\Denim sewn around a grid and used to filter our pool water?
    21X41, 30,000, ig, vinyl,48sf de, 1hp hayward super pump, 2" piping, 2 skimmers, 1 main inlet, 2 return, built in 1988, no enclosure, lots of trees around, direct sun. Thanks in advance to all who have answered my questions.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: new kind of filter?
    uhh.. it will filter something.. i guess.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    The best filtration is your DE filter.
    You can certainly augment it with a DudaDeisel bag, they seem to be the cheapest alternative to a "Slime Bag". They go down to 1 micron and from what I have read, they can even catch things that DE misses.
    http://www.dudadiesel.com/search.php?query=filter+bag
    You could even use this to direct your backwash or vacuum to waste water back into your pool, as it'll pull everything out of it, more than your filter will. Saving you on water & chemical waste. A win win! Cleans up in the washing machine after hosing it out.
    Of course, if you really want to trick out your DE filter, you could flush out all that DE, acid wash the grids then replace it with Cellulose Fiber Media. Super awesome and filters a little finer than DE does, uses less, weighs less and cleans off the grids better when bumping. If you don't have a bump DE filter, then when you backwash it, you just add more cellulose as you lose a lot more than with DE, roughly 95% or so when backwashing. So your grids stay cleaner of spent media, starting fresh each time and much much less overall maintenance. Not to mention cities don't whine about it and you don't need a collection tank for backwashing.
    DE goes down to about 5-6 microns and cellulose goes down to 1-2 microns.
    Denim just doesn't have enough layers and tight enough weave to it, compared to cartridge filter media. Hosiery would get you farther I would think.
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    Mar 2011
    Scottsdale, AZ
    406
    What ever you do, dont google
    "blue jean filter"
    May 2011
    Orange County, CA
    696
    Quote Originally Posted by Just-a-PB
    "blue jean filter"
    Okay, that was a bit too hard to resist!
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
