Results 1 to 10 of 10
Thread: To Filter or Not to Filter
    Ksnewman's Avatar
    May 2012
    Middle Tennessee
    173
    We will have a waterfall with the pool and I have been reading through posts trying to find out if we should have the waterfall bypass the filter. I think I have seen pros and cons by I am not sure if that is an option.
    18x36 kidney 20,000 gallons IG vinyl. Pentair Easy Touch 8 w/IntelliChlor IC40. Triton II TR100. Pentair Intellifllo Variable Speed. Waterfall/Jump Rock. 2 Pentair Intellibrite lights. TF-100 Test Kit. And a very happy husband who gets to play in the pool without having to take care of it.
    Mike_W's Avatar
    Aug 2011
    Orange County, California
    142
    Re: To Filter or Not to Filter
    I am not "in the industry", but, if the waterfall was putting water into your pool (as mine does), why would you not wanted it filtered? Bypassing the filter for the waterfall would require additional pumbing and valves, adding cost. It is not clear to me what the savings would be.
    Will your waterfall have it's own pump or will it use the pool pump and just redirect water to the waterfall? Will it have its own suction line?
    Mike
    ~17' x 34' IG pool with attached spa - 20500 gallons - Gunite with a "pebblesheen"-ish finish
    Jandy iAqualink with iPad and Jandy PDA remote - Pentair IntelliFlo VS 11018 Pump
    AquaRite SWCG - Pentair SMBW 4060 DE Filter - Really Old Raypak heater
    "Wall-E" an Arneson-Hayward Navigator - A couple of Jandy/Zodiac WaterColors LED Lights - Blue-White F-1000 Flow meter
    Apr 2012
    Klein Tejas
    249
    I think the issue is pump volume/pressure.
    A water feature might exceed the recommended volume of water the filter can handle.
    Pool is DONE!
    Pentair Intelliflo VS3050
    Pentair Easy Touch 8 + actuators + swg
    Pentair IntelliPH
    Pentair 400btu HD heater
    3- Jandy WaterColor LED's
    Hayward C5030 525sqft cartridge filter
    Waterway spa blower
    Apr 2012
    Newton, NC
    173
    We have a waterslide that has its own pump. There are 2 additional drains in the pool for suction. And, there is one additional return in the pool to help adjust the amount of water going to the slide. This water does not go through a filter or heater. This keeps it simple. One button push on the Pro Logic panel or a remote turns the waterslide on or off. Using the waterslide has no impact on using the main pump, filter, and heater for spa usage, spa spillover, or just filtering the pool.
    Vince L
    16' x 37' fiberglass pool, 8' fiberglass spa, Hayward Swimclear C3030 filter, Hayward EcoStar VS pump, Goldline Pro Logic PL-PS-8, Goldline SWCG, Goldline Sense & Dispense pH control, Fiberstars LED's in pool & spa, AquaCal SQ175R heat pump, SR Smith Typhoon slide, Polaris 9300xi robotic cleaner, TF-100 Test Kit
    Ksnewman's Avatar
    May 2012
    Middle Tennessee
    173
    Quote Originally Posted by Mike_W
    Mike
    There will be 1 pump for pool and waterfall. I am not sure about the suction line.
    Ksnewman's Avatar
    May 2012
    Middle Tennessee
    173
    Quote Originally Posted by bigdav160
    I think that was my concern.
    Mike_W's Avatar
    Aug 2011
    142
    Do you know the pump rating? Mine is a 3 hp variable speed sized for the spa, and the filter is sized to match.
    Mike
    Ksnewman's Avatar
    May 2012
    Middle Tennessee
    173
    Mike
    I believe it is 3 hp variable speed. The filter has a flow rate of 63 GPM and max pressure of 50.
    30,403
    I am jumping into the middle of this discussion but a 63gpm filter is too small.....both for that pump and for that pool. I would suggest having at least a 100gpm size filter for the pool.
    I cannot comment knowledgeably on the pump size because of the waterfall requirement but, if it had no waterfall, that pump would be much too big for the pool (and current filter) alone.
    Ksnewman's Avatar
    May 2012
    Middle Tennessee
    173
    The filter area is 3.14 sq ft. Flow rate is 63 GPM at 20 GM@20 GPM FT2. Turnover capacity is 45,360 gallons at 2 turnovers per day. Pentair's manual has: As a minimum, you must be sure that your system will turn over the total volume of water in your pool at least two to four times in a twenty-four hour period.
    With all this info, does, this filter seem appropriate for this size of pool? I am beginning to panic that I may have purchased the wrong equipment.
    I thought the variable speed pump benefit was that you could control the flow of water at lower speed settings and then set higher settings for filtration/cleaning/waterfall, etc.
    Thanks for the input!
