Thread: Muriatic Acid
    Muriatic Acid
    I have a CAT4000 connected to a 50,000 gallon pool and a CAT2000 connected to a 2500 gallon hot tub. Both use acid feed to control pH. Do I need to dilute the acid before I feed it or can I use straight muriatic acid?
    Re: Muriatic Acid
    Bump
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    Re: Muriatic Acid
    I think the only reason you would need to dilute it is if you need a lower setting. Meaning, you have it on the lowest setting and it's still dispensing too much.
    14.5K gal Plaster IGP, Intelliflo VS, EasyTouch 8, SWG, IntellipH, Clear and Clean 420 Cartridge Filter, Attached Spa, H400IDL2 NG Heater
    Re: Muriatic Acid
    It's an automatic dispenser. The system checks the readings every second. So it feeds until it reads that it's satisfied.
    Feb 2008
    Denton, TX
    5,061
    Re: Muriatic Acid
    Have you posed your question to the manufacturer?
    Re: Muriatic Acid
    No not yet.
