Thread: When to add stabilizer (Fall vs. Spring)?
    MBMMPool's Avatar
    Ohio
    15
    Hey, guys-
    My 18x36' pool is currently filling following a planned Vinyl Liner replacement. After a few days of cycling to check for leaks, the pool will be winterized (I live in Ohio- we are DONE swimming!). Pool has an automatic cover that will be closed until spring.
    Question: Any benefit of adding/dissolving stabilizer NOW, or should I just wait until Spring? As the water will not be exposed to any sunlight over the winter, will the stabilizer help maintain chlorine level in any real way?
    Thanks for your time & opinions.
    18x36' 25,000 Gallon IG Vinyl Pool
    Coverstar 3000 Pool Cover
    Sand Filter (S244T)
    AO Smith 2Green 1HP Two Speed Motor W/Timer
    Pentair IntelliBrite 5G LED Lights
    Re: When to add stabilizer (Fall vs. Spring)?
    I cannot see how it would do any good in a covered pool. However, algaecide might be advised. We need to hear from one of the northern folks about this.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    It seems to me that cya would help like it does for indoor pools by moderating chlorine and keeping a reserve.
    -sent with Tapatalk 2
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Wait until spring. Covered pool, new water, cold temps - minimal chlorine loss. Just my. 02.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Jun 2012
    Mint Hill, NC
    2,589
    There are numerous posts where chem geek posts about indoor pools and suggests that having some CYA in them is smart as it moderates the chlorine's affect on swimsuits (and I presume reduces impact to liners, and covers, etc) and provides a reserve. I don't see why over the winter that wouldn't be useful (other than the swimsuits part!) I'm not saying put a whole bunch in - 20-30ppm total should be sufficient.
