Results 1 to 8 of 8
Thread: Do you really need antifreeze in the lines?
    Jun 2012
    Barrie, Ontario, Canada
    28
    It is my first year closing my in ground pool, we bought the house and the pool is 10 yrs old.
    And I got a company in to close it, a respectable company in the community.
    I got the same company the old owners had closing/opening the pool for years.
    However when they close pools, they dot use antifreeze in the lines, they just blow the lines out.
    Has anyone heard of this?
    Size - 50,000 Litres / 13,208 g (32' x 16' x 4.5' Sport Pool)
    Filter - Jandy CL460 Cartridge Filter
    Salt Water - Zodiak LM2
    Pump - Jacuzzi Magnum Force
    Heater - Laars LT LT250NS-C
    IG Pool (Vinyl)
    2003-2005 ish
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Do you really need antifreeze in the lines?
    Antifreeze is a backup in case the line leaks or a low spot in the lines keeps you from getting all the water out.
    Quote Originally Posted by JohnT
    Agree, but if the water is stuck in a low spot, wouldn't it be below the freeze line in most cases?
    TF-100 Test kit, 24,000 gal. free form Vinyl. mybluepool AC-600 SWG, STA-RITE S7MD60 DE filter, 3/4 HP STA-RITE MPRA6D pump, Polaris 280 w/booster, Raypack Propane heater, Looplock mesh cover; All located in New England.
    SW Indiana
    9,199
    Quote Originally Posted by run53
    Not around here. The deepest I've seen it freeze here is 21", but none of my lines are much more than a foot to a foot and a half deep except the drain. In northern areas the ground probably freezes below the pipes every winter.
    OK...I'm in NE and the low spots of all my lines are at least 36-40" below ground.
    Jun 2012
    Oakton,Va
    39
    I was wondering the same thing - I live in the Washington DC area, do I need antifreeze or just blow out all the lines?
    35000 gallon inground, 2hp Whisperflo, Pentair FNS Plus, Polaris 380
    22,550
    The antifreeze is kind of a belt and suspenders approach. Obviously if you can blow all the water out of the line, and keep it out, it doesn't need antifreeze. Depending on your certainty of being able to do that determines whether you should use antifreeze or not. So if you're not absolutely sure you can get the water out of the line to a point below the frost line, then adding antifreeze is a insurance.
    Qwaxalot's Avatar
    Jun 2012
    439
    We use the anti-freeze as an indicator. As we blow out the lines, the presence of anti-freeze at the returns indicates that the lines have been evacuated. Any anti-freeze still in there is just insurance
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
