Thread: Waterfall source from drains or wall?
    wpbucher's Avatar
    Feb 2012
    South-Central Pennsylvania
    132
    The pool will have a waterfall that is on a separate pump. One PB has the source (suction) from two floor drains. There are already two floor drains tied into the filtration loop...so the pool would have a total of four drains. Another PB has the source from an inlet on the wall of the pool ... with the appropriate anti-entrapment cover.
    Is either a "better configuration"?
    What are the advantages/disadvantages of each configuration?
    2013 HotSpring Grandee with Ace Sanitizing System
    25K IG vinyl pool with Alps spillover spa and waterfall. Build Date: June 2013
    Triton II TR100 Sand Filter, Pentair Master Temp 400 natural gas pool heater, Intellichlor SWG, Rainbow Chlorine Feeder
    Pentair VF filter pump, WhisperFlo 2 hp WFE-8 waterfall pump, WhisperFloFX 2 hp spillover spa pump
    Intellibrite 5G (2 pool and 1 in spa) lights :: TFT-100 test kit, Taylor K-1776 test kit
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: Waterfall source from drains or wall?
    Is the pool going to be heated? If not then the deeper water will possibly be colder and pulling from there may make things chillier under the waterfall. On the other hand it will aid in reducing temp differences if it runs a lot, and may improve bottom circulation - but with two drains already it may be overkill.
    - Sent using Tapatalk
    I just built my pool an I did the 2 main drains setup for mine I have 2-2foot falls and 1-4foot. We used a jandy wtf120 pump and ran it through a filter. Worked out great.
    Go with the wall mounted. If you have them at the bottom of the pool with the drain you will suck debris in and have to empty the pump basket. I have side mounted for my water features and have never had any debris in the pump basket in 3 years.
    Phoenix, AZ
    Unknown pool size -Diving pool
    May 2011
    Orange County, CA
    696
    Our waterfall is plumbed with a separate 2HP Whisperflo pump using two intakes on the side wall under the skimmer. The two intakes are designed to prevent entrapment. The advantage of the system is that the waterfall is entirely separate from the pool's main filter circuit. So, no issues running the waterfall regardless of whether the pool is in spa or pool mode. Plus, I can use the waterfall intake to backflush the cleaner line with the turn of a couple of ball valves. This turns out to be a very useful setup with our vacuum side auto cleaner (Zodiac MX8).
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
