Thread: Under Construction in Atlanta, GA
    Hi all. We started construction at the beginning of September and have been steady at it.
    • Gunite Pool - approx 29,600 gallons 22x41,3 ft to 8.5 ft deep
      Sun Deck about 8 ft across and out done in flagstone
      Flagstone coping
      Hot tub
      Firepit
      1390 sq ft pavers around pool
      3 ton waterfall with cavetop
      21' marine grade slide w/boulders and pathway
      2 HP Jandy variable speed pump
      1 Jandy booster pump
      Jandy Remote System
      Polaris 9300 Robotic cleaner
      400,000 BTU heater
      120k heat pump
      Pebble Tec - black marble
      Intellibrite lighting
      3 bubblers
      3 spray fountains
    Re: Under Construction in Atlanta, GA
    Here are the pictures (I think)?
    [attachment=2:2iwtk86e]pool11.JPG[/attachment:2iwtk86e][attachment=1:2iwtk86e]pool22.JPG[/attachment:2iwtk86e][attachment=0:2iwtk86e]pool33.JPG[/attachment:2iwtk86e]
    [attachment=0:25vc70fb]pool44.JPG[/attachment:25vc70fb]
    Jan 2011
    Richmond, Texas
    595
    That is going to be a nice pool.
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    Oct 2012
    North Georgia, USA
    6
    We are interviewing Pool Builders right now for a start-date of Jan 2013...
    What area of GA are you located in?
    Who is your builder?
    Are you happy with them and would be willing to give a recommendation??
    THanks for any help.
    LaVenderBlue
    41'x22' freeform, 25,000 gallons. Stonescapes mini-pebble: color AquaBlue. Jandy CV CL580 filter, Jany 1.5 HP Vsp pump, Jandy AquaPure SWG. 5 ton twin waterfall and 17' slide (only running when kids are playing in the pool). Attached Spa with overflow (runs continuously with the Filter Pump). Gas heater for Spa, electric HeatPump for pool. Polaris 9300xi cleaner. Double Main drains, 2 skimmers, Auto-Fill.
    Feb 2008
    Denton, TX
    5,061
    Looks awesome!
